Hole interpolation accuracy with endmill - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 74
  1. #21
    Jan 2014
    Oregon
    741
    180
    548
    Quote Originally Posted by cgrim3 View Post
    Damn 1800 bucks! That seems like a lot of money to spend on that every year
    While it can be a great piece of data to have and collect, very few shops actually need an annual ballbar test. Again, lookup how to check for lost motion. That is good enough for 99% of applications.
  2. #22
    May 2017
    Minnesota
    1,776
    2318
    1181
    That's about six bone plates.
  3. #23
    May 2017
    Minnesota
    1,776
    2318
    1181
    Quote Originally Posted by boosted View Post
    While it can be a great piece of data to have and collect...
    It's not just data collection; they adjust the backlash compensation and the error mapping to minimize the error in the machine.
  4. #24
    Nov 2014
    Florida
    6,209
    2463
    3085
    So I guess tolerance is tolerance.... 1.002" seems an odd size though? Is it a slip fit on a 1" pin? If you can get a 1.002" and not a 1.003" I'd say you are good to go, or as you said a bore mic, averaging the reading (1.0021-1.0025" etc).... I don't think .0003" out of round is bad on 23007 machine at all. And as mentioned, need better - tenth set boring head....
  5. #25
    Jan 2014
    Oregon
    741
    180
    548
    Quote Originally Posted by mhajicek View Post
    Again, the backlash comp can be achieved with just standard lost motion checks and adjustments.
    I do like ballbar tests, they are great for tracking long term accuracy, trends, etc... If I had a fleet of similar machines we would definitely ballbar all of them annually. It's just not a necessity for most environments. Most of us don't have machines and processes that are consistent enough that measuring and tuning circular motion at very high accuracy will be critical.
  6. #26
    Feb 2013
    Idaho
    850
    192
    972
    We did a few studies on this for a military/ aerospace company I had the misfortune of working for. They insisted on using circular interpolation for holes rather than reamers or boring heads. (They are the reason I prefer not to fly).
    You can comp in any hole to make it seem like it's to dimension if you are using a pin gauge, but as you found it is not necessarily round. A hole that passes a pin gauge may very well fail in a CMM or an optical system... the inverse is also true (set comp with a CMM and then have the customer reject the part with a pin). If you choose to make parts using this method, it pays to know how the customer will be qualifying the parts.
    I found that I could achieve better circularity by helically boring the parts with the tolerance set very tight. This broke the code into very small line segments rather than using a G02/G03. I would love to go back and revisit that theory if I ever have time and the appropriate test equipment sitting around.
  7. #27
    Dec 2020
    Maryland
    222
    131
    44
    Boosted, sorry if this comes off as a noob question, but how do you do lost motion checks and adjustments? I am not entirely sure what lost motion checks mean.
  8. #28
    Dec 2020
    Maryland
    222
    131
    44
    When you say lost motion, do you just mean backlash?
  9. #29
    Jul 2006
    Hillsboro, New Hampshire
    12,783
    2905
    8846
    Guessing here, but "lost motion" may also include stiction, belt stretch, etc., where backlash might just be the loss of contact from one element/group of elements (bearings) from another.
    Just my WAG...
  10. #30
    Apr 2018
    7,562
    3684
    I don't know why you guys even consider this stuff .... if you want a round hole, a boring bar is dependent on the spindle bearings. Interpolated hole depends on spindle bearings, end mill concentricity and cylindricity, axis accuracy and backlash and velocity and position control.
    No contest.
  11. Likes csteen liked this post
  12. #31
    Dec 2020
    Maryland
    222
    131
    44
    So this morning, we checked the backlash of the machine in the x, y, and z. I was pretty surprised it was out so much. Backlash in the Z is .0004, the Y is .0005, and the X is .0003. I am going to get somebody in here to do a ball bar test or calibrate the machine. You all think this is too much? I know I can probably do a backlash comp in the controller but I want to make sure nothing else is going on which would cause this much backlash (such as a bent ball screw, bad bearings, etc).
  13. #32
    Jan 2005
    CANADA
    Saskatchewan
    10,322
    1413
    3767
    You can't really adjust real mechanical backlash out of a machine in hopes of getting rounder holes. The backlash basically mucks with the PID setting of the servos, meaning the parameters have to be set 'looser' because the servo loop cannot be as tight as a theoretical zero backlash. Servos find position by cutting the error in half many times over (very quickly) which involves decelerating to an exact stop at exactly the right position. It might be tuned to do this electronically so far as the encoders are concerned, but if your machine rapidly stops a heavy table, and real backlash exists, then that table position is going to be undefined within the range of backlash. The servo will have to hunt in both directions and settle on the best average it can find. That would be for positional moves. Imagine the complexity of the servos passing any quadrant line and trying to tune out that table inertia and the ballscrew backlash and getting it perfect at the quadrant line. Slim chance. In Z axis of a vertical mill, you've got significant weight bearing down consistently, so backlash comp could work pretty good there because the head will never find itself 'above' the backlash.
    If you want round holes, bore 'em.
  14. #33
    May 2019
    1,911
    1056
    1228
    If it were me I would be happy with 3 tenths on that machine and bore anything that needs to be held tighter.
    Often it is more valuable to know what your machine can and can't do than to have a machine that can do almost anything.
  15. #34
    Feb 2020
    Alabama
    366
    151
    103
    we are using smoothing and feed optimization. We are using fusion 360. The tolerance set for smoothing is .00001
    Feeds and speeds: 2000 rpm, feedrate of 10 ipm. It is aluminum and we could have gone faster. The machine has an 8000rpm spindle so we try not to go too fast. This is a one-off part so we didn't apply super super fast feed rates for production.
    I do not know how to apply look ahead in fusion or on the machine. How do you do this?
    Why would you use smoothing on a round hole? That makes no sense. I would recommend breaking your arcs into quadrants and using G60 (exact stop positioning)so you can see where the problem is.
  16. #35
    Dec 2020
    Maryland
    222
    131
    44
    Coronavirus, I'm not entirely sure how to do that in fusion. I don't think fusion gives you that level of control but I might be wrong
  17. #36
    May 2019
    1,911
    1056
    1228
    Try selecting a sketch of the circle rather than the solid. Back when I was playing with it that made a huge difference on the toolpath. IE it would output 1 arc rather than linear moves or a ton of tiny arc
  18. #37
    Dec 2020
    Maryland
    222
    131
    44
    To interpolate a circle with an endmill, I generally use the circular or the bore function for interpolation, then use a contour toolpath for finishing. These toolpaths don't give you an option to select a point. You must select the sketch of the circle.
    Anyhow, we are having somebody coming out here to calibrate the machine. It's funny because our daewoo Puma lathe is from 1998 and that has like 30 millionths backlash in the X and Z. This daewoo mill is newer and has backlash in y of .0005
  19. #38
    Feb 2020
    Alabama
    366
    151
    103
    Me either. I have never used fusion, but I would try drawing arcs instead of circles if fusion does not have a break arc feature when posting.
  20. #39
    May 2019
    1,911
    1056
    1228
    It's been a while but I seem to remember being able to select the edge of the solid with contour which is not what you want. You want to hide the solid and make the sketch itself visible and select that. Maybe it's changed since I last used it since the bastards were making changes every week when I used it.
  21. #40
    May 2017
    Minnesota
    1,776
    2318
    1181
    Quote Originally Posted by EmanuelGoldstein View Post
    No contest.
    No contest indeed. I sometimes get a print and model at 5pm, and put the part on the engineer's desk by morning. I can throw an endmill in and get it done; I don't have a full set of boring bars for all length and diameter ranges. 99% of the time the hole will be a locating bore or a press fit for a pin, so if the gauge pins say it's good, it's good.
  22. Likes CORONA VIRUS liked this post
