Holes in the end of large plates
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Mar 2019
    Wisconsin
    6
    Default Holes in the end of large plates
    Hi Guys,
    Question, how would you drill holes in the ends of long plates? For example, picture a fixture plate that is 1/2" x 12" x 24". It calls out holes on the 1/2" face with a pretty tight position tolerance. Im assuming maybe a manual mill? We are a full CNC shop at the moment.
    Oct 2005
    17,276
    Are you wanting to gundrill ?
    We have gundrilling specialty shops around that doo mold bases and such.
    Might want to look around for one in your local.
    Sep 2010
    Oklahoma City, OK
    4,834
    855
    2002
    How many? Might be time for a right angle head on a VMC.
    Jan 2013
    Erie, CO
    182
    34
    17
    On a manual mill I used an angle plate indicated square with table, to let the plate hang behind the table. Than made clamps to hold the plate with a guide rail to keep everything at right angles. It pretty fast to change ends with the guide rail keeping things in same place once you lock the table in place.
    Taft-Peirce UNIVERSAL RIGHT ANGLE IRONS by Suburban Tool, Inc.
  5. Likes Pete Deal liked this post
    Feb 2006
    Republic of Texas
    2,550
    Quote Originally Posted by legacymachining View Post
    Hi Guys,
    On a plate that size and larger, we would use our horizontal boring mill, circa 1911. Smaller than that would be in the big VMC.
  7. Likes bryan_machine liked this post
  8. #6
    Jun 2012
    Michigan
    5,082
    4634
    3064
    Hang it off the table on a Bridgeport.
    Farm it out.
    Or buy a mill that has that capacity.
  9. Likes SIM liked this post
  10. #7
    Sep 2002
    People's Republic
    4,389
    421
    2671
    Funny haven't been in a shop without 'a' manual bridgeport, or at least one with a prototrak
    Suppose a CAT right angle head used is cheaper than a bridgeport
  11. #8
    Feb 2004
    Staten Island NewYork USA
    3,836
    1143
    1880
    Quote Originally Posted by Mtndew View Post
    Farm it out.
    That about sums it up...BUT
    On some CNC Vertical milling machines the spindle will go past the table edge OR the table goes past the spindle depending on how you look at it. On some of my Haas machine the spindle goes about an inch past the table. So I toss up an angle plate then hang and clamp a plate off table in the back by a few inches. That allows me to do some machine work, holes etc on the sides or ends of some plates.
  12. #9
    Feb 2013
    Madison, WI
    1,080
    1157
    694
    If the hole is shallow enough, I'd hang the plate off the side of the table in the VMC. Otherwise an angle plate on the drill press.
  13. #10
    Nov 2014
    68
    9
    36
    Clamp on drill fixture with hardened drill bushings, works well in some situations, depends on qty / Tol. ...etc
  14. Likes mmurray70, gustafson liked this post
  15. #11
    Feb 2013
    Idaho
    755
    170
    868
    I usually go down to my neighbor's shop and use his Bridgeport... he doesn't charge me anything, but I have to put up with his bullshit about how the "fancy" CNC shop can't do simple manual work. Then again, he also pisses and moans about being broke all the time
    I don't want to acknowledge my own stupidity (at this point it would be a bit redundant anyhows), but the last time I needed to do holes on the end of long plate, I fixtured the plates on the cross slide of my lathe and put the cutting tools in the three jaw chuck. Worked slicker than shit. Set the Z using the fixture, Y using the cross slide, and drilled using the carriage (using what would be mill coordinate system kinda sorta...). Setup wasn't much worse than racking the head and putting an angle plate on a Bridgeport and I think it was quicker to run. White trash horizontal boring mill.
  16. #12
    Mar 2019
    Wisconsin
    6
    Man, some cool ideas, especially the lathe idea. I think for the volume and variation in work size i can make it work with maybe a good right angle plate on the machine table. Then use the through holes in the plate to bolt it to the angle plate?
  17. #13
    Mar 2011
    Geneva Illinois USA
    6,428
    2807
    2509
    No one has a horizontal mill anymore?
    Tom
  18. Likes Illinoyance liked this post
  19. #14
    Aug 2010
    Medina OH
    2,182
    259
    1058
    I keep an old horizontal around for work like this. That being said, you didn't specify HOW tight the tolerance was?
    I also keep an old drill press around for some things like this as well. From the base to the spindle is 40". I wouldn't use this for anything I would consider precision or tight tolerance.
    G00 Proto, that isn't white trash at all, just good use of your tools. I think its funny now days everyone things lathes are only for turning round things. There are a lot of "common sense" uses for machines that have been "forgotten". My old south bend, that I just hated to get rid of, was made with 4 T-slots on the carriage, the top of the carriage was machined so that you could bolt anything to it and bore a hole.
  20. Likes TheOldCar, Ray Behner liked this post
  21. #15
    Mar 2007
    Salem,Ohio
    680
    19
    327
    Quote Originally Posted by TDegenhart View Post
    Tom
    That's what I was thinking. We have an old Cincinnati sitting at work for stuff like this. It even has digitals on it. If not that, we could use one of our 5 boring mills.
  22. #16
    Oct 2009
    Oregon
    4,769
    5149
    2463
    This is a joke right?
  23. #17
    Aug 2010
    Medina OH
    2,182
    259
    1058
    Quote Originally Posted by Garwood View Post
    I doubt it. The last shop I worked at had no way to square up plates, or put holes in the sides.
    There are LOTS of shops I have been to that completely lack basic tools.... but they got lots of fancy CNC's!
    This model works great if all you do is production and all of your parts fit in that envelope.
  24. #18
    Oct 2010
    Oregon
    5,291
    4741
    1939
    Don't neglect the value of building a drill jig with precisely located drill bushings and locators to control hole location, and then using a cheap&sloppy drill press with an angle plate on the table or base to control hole axis parallelism. If the plates were long enough, I might do that even though I have a horizontal mill. Of course, if they are too long to fit under the drill press spindle, there's no choice but to hang them off the mill table with an outboard support.
  25. Likes Limy Sami, gundog, Illinoyance liked this post
  26. #19
    Virginia
    30,475
    7561
    9518
    Quote Originally Posted by Omega View Post
    Yazz. It would be worth fabbing that jig as it migrates the work off the revenoo-earners to the ignorant drillpress, yet still saves money off the faster set up and cycling. Only 24" long, so BFD.
  27. #20
    Jul 2007
    Missoula Mt
    270
    6
    99
    I use a G&L HBM with dro...Phil
  28. Likes bryan_machine liked this post
