Texas Tim
- Feb 26, 2006
- Lake County, IL. USA
I know conventional cnc turning, but have no swiss exp. We have a problem in my dept with an iscar indexable cutoff tool burning up on a semi regular basis. The owner of the shop is the only one who can setup the tsugamis. Tired off replacing cutoff tools, I put an M00 before the cut-off, so operator could watch & feedhold if insert breaks. Noticed a large nest of chips often hanging on at this M00. Had operator remove nest before hitting cycle start again, no more broken cutoffs! Owner unhappy! Machine must run unattended! Need advice.
Heres what i can tell you, bearing in mind i dont know these machines at all. They run 6061 alum bars ground to .750 dia. the part gets an id bore around 1/2" and some id grooves, and an od profile that winds up kind of cone shaped, maybe 1-1/2" long. The part does get grabbed by a smaller sub spindle that finishes the back end. The owner tells me the nest of chips is coming from the boring bar, he cant get the chips to break, even tho he programs these choppy z axis moves pecking to try and break chips. One thing seems weird to me, but the owner tells me it has to be this way... The iscar cutoff tool isnt really cutting off, rather it just faces off the fresh bar end after each piece. I asked, couldnt we use a tool more designed for facing, like a tnmg or something? Owner says cant do it.
Does everyone really have to face off bar ends with a cutoff tool on tsugamis? And can anyone (swiss pro?) give me any other advice i might tactfully relay to the owner to steer him in the right direction to get this back to unattended profitability?
Tim
Lake county, illinois
Tim
