kvom01
Hot Rolled
- May 18, 2008
- Cumming, GA
Having licensed the most recent version of GW and watched the two videos, I felt "enabled" to try again. Now I wanted to do a facing cut in CRS to a depth of .300".
GW suggested a 48% radial engagement, 2600 RPM, and 23 IPM at full DOC with a 7/16 carbide endmill and 1/38 "stickout". So with trepidation I plugged those numbers into CAM and single stepped through the first two cuts. I found that the noise (squeal) was really loud although the finish (not a critical factor) was fair. The bad part was that the end mill pulled out of the collet slightly on the second pass, which was conventional milling (I was using a back and forth cut pattern). So now I have a ramped cut and a too deep DOC on one side.
So the first question for the forum is why the collet pulls out on the pass using conventional milling, while the first pass using climb did not.
Although the part is now unuseable, I decide to continue to try different options. This time I really cranked down on the drawbar. I reduce the DOC to .100 in GW with the same radial engagement and get 3056 RPM at 23 IPM. I plug this into CAM and run it single step for a couple of passes. Chatter is now gone or pretty minimal in climb milling, but is perceptible in conventional. So I modify the CAM settings to do each pass in climb and run the program to completion. The results are very satisfactory as to finish.
The remaining question re this part has to do with the lead in move. I had specified a tangential move on each pass, meaning a G3 from outside the part to the start of the next cut. This move had the same feed rate as the rest of the cut. So I am now wondering if the move that enters the side of the material needs to be (significantly?) slower in order to not shock the endmill. It did seem to have a somewhat louder sound on entry vs. the longer G1 that follows.
Thoughts?
Thoughts?
