I want to make some "doughnuts" to go in my spindle to support long stock. I have read the various forum posts on the subject but have some questions.
I am going to make some delrin disks (or doughnuts) and will put an o-ring groove in the od and put a soft buna o-ring (from Mcmaster) on it so it fits snuggly in the spindle.
I was thinking I would need maybe 4 of these along a 36" bar. Is that enough or too many?
I was thinking they would be about 1" long. Is that a good length or should I make them longer?
My spindle is 66.5mm(2.618") ID. I was going to get a 2-5/8" OD(2.637" actual) o-ring and make the disk diameter 2.52" DIA. Is it ok to have the disk nearly .1" undersized and have the o-ring take up the difference? I want to be able to get them in/out easily enough.
How close to the stock diameter does the ID of my liner disks need to be? As one example, if I want to use 0.5" hex stock which from point-to-point is 0.577" OD, can I bore the liner disk to 0.625" or should I get it closer to .577?
-Tom
-Tom
