Hooo boy. Try to find a 2deg taper x 1.25 reamer on short notice!
Results 1 to 16 of 16
    Sep 2008
    Eugene Oregon
    293
    13
    18
    Default Hooo boy. Try to find a 2deg taper x 1.25 reamer on short notice!
    Isn't happening I guess. Talked to XKut and they're out, the only supplier I can find dimensions on big enough to work. 1.22" on the big side of the hole with 2"/ft taper. Anyone have one in their pocket I can stop by and pick up? lol
    Jul 2015
    Wisconsin
    286
    16
    99
    How deep? Can you use a tapered endmill?
    Jan 2002
    West Coast, USA
    9,346
    613
    6822
    Assuming the title is correct (2 deg. taper) . . .
    Anyone sharpen reamers in Eugene? Wouldn't be cheap but someone with a decent T&C grinder should be able to make you one up from a standard reamer.
    I doubt we're talking blacksmith tolerances, but you could grind a taper on the blades of an adjustable reamer and fight it for a hole or two.
    What's confusing to me is that the title says two degrees and the body of the question says 2" per foot. I'd think someone would have the 2" per foot taper in stock or be willing to grind something to fit . . .??
    Sep 2008
    Eugene Oregon
    293
    13
    18
    Quote Originally Posted by MaxPrairie View Post
    Unless something throws a wrench in the works that's what I decided to do. I have a grinder buddy that said he can fix me up as soon as I can get a 1.25" EM to him.
    Mar 2009
    Brunswick Oh USA
    4,810
    5724
    2925
    Seems like if you taper an endmill to use as a reamer, it will suck itself in the hole. For your sake.....hope not.
    Jun 2012
    Michigan
    6,267
    5862
    4014
    Does anyone stock a reamer that size with that TPF? Seems like something that would normally be a special.
    Even then I would imagine that it's pretty pricey.
    Is there any way you can 3D machine the hole?
    Feb 2008
    MI, USA
    1,069
    75
    442
    I'm on the confused team here.
    Is it 2 degrees or 2" per foot?
    If it is 2 degrees, is it 2 degrees per side, or 2 degrees included?
    Standard taper pins seem to have 1/4" per foot, which works out to about 1.2 degrees included. I assume this isn't for a standard taper pin.
    Sep 2008
    Eugene Oregon
    293
    13
    18
    Quote Originally Posted by dandrummerman21 View Post
    2"/ft taper per MOOG for a SuoerDuty lower balljoint.
    Sep 2008
    Eugene Oregon
    293
    13
    18
    Quote Originally Posted by Mtndew View Post
    The only source I've found for this one is out of normal stock, yet they still have a current ebay listing for it. So far all the others I've found with the same taper are smaller dia. so won't work.
    I've never seen mention of a conical interpolation? We we talking about that last night trying to come up with a solution.
    Sep 2008
    Eugene Oregon
    293
    13
    18
    Quote Originally Posted by Ray Behner View Post
    Good point. Maybe I'll G2 around the hole instead of plunge cutting.
  11. #11
    Jul 2015
    Wisconsin
    286
    16
    99
    Quote Originally Posted by DMSentra View Post
    I will typically buy a tapered endmill and pocket mill the tapered wall. Do it a lot for tapered bushings. 4 deg is pretty common.
  12. #12
    Sep 2008
    Eugene Oregon
    293
    13
    18
    I haven't seen one with the 9.5deg this job needs
  13. #13
    Jul 2015
    Wisconsin
    286
    16
    99
    I always get them custom ground… but a 1.25 carbide plunge will likely chatter so I would pocket mill it.
  14. #14
    Oct 2009
    Oregon
    6,591
    7026
    3898
    I have a straight flute 1.250" carbide tipped reamer you could grind. I'm about 2 hours NW of Eugene.
    Are you making Superduty knuckles?
  15. #15
    Feb 2008
    MI, USA
    1,069
    75
    442
    I wonder:
    How well would taking a smaller taper reamer with the same taper per foot and use that like an endmill to interpolate the hole?
    Might be a bit slappy but should work if you only have a few to do.
  16. #16
    Sep 2015
    Ohio
    1,903
    1232
    2041
    If you have a rotary table and a BP you could nod the head and crank the turntable to mill your taper using a standard endmill.
  17. Likes atex57, GM liked this post
