How to avoid this machine crash
Results 1 to 11 of 11
    Aug 2006
    greensboro,northcarolina
    2,330
    136
    543
    Default How to avoid this machine crash
    Turning a simple part in a CNC lathe, face, turn, thread, groove and cut off, 30 part run, the back side will be done in a second op. On the 21st part, at cutoff the part flips into the counter bore in a chuck jaw at just the wrong time, and smacks the turret hard enough to stop the chuck and knock the turret out of alignment. Never seen that happen in 30 years of CNC lathe operation. Does anyone go to the trouble of putting caps into the counter bores of the jaws of their 3 jaw to avoid something like this? Or is there some other trick? Or is this just a once in a lifetime piece of bad luck?
  2. Likes Bobw liked this post
  3. #2
    Jan 2013
    Plainfield, Indiana, USA
    1,702
    1281
    913
    Try running larger parts that won't fit in the c'bores.
    Sorry, couldn't help myself.
    Keep some plastic plugs around that fit the cbore's like the plugs they stuff in air / hydraulic fittings to keep dirt out. Only need them in the inside screws.
    Sep 2015
    Ohio
    1,032
    598
    1003
    Hang the stock out farther so the part doesn’t get wedged between the cutoff and jaws?
    Jan 2006
    Connecticut
    1,588
    672
    772
    Collet chuck.
    Sent from my SM-G930V using Tapatalk
    Jun 2013
    Oregon
    1,474
    514
    887
    If you are using soft jaws, cut the jaws at a 45 to give you more clearance.
  7. Likes Philabuster liked this post
  8. #6
    Sep 2010
    Oklahoma City, OK
    4,030
    706
    1725
    I think that falls into the category of 'head scratcher' or 'I'll be damned'
  9. Likes Hodge, Fancuku, TeachMePlease, barbter liked this post
  10. #7
    Nov 2013
    Utah
    4,258
    1153
    2323
    I'd be willing to bet that scenario never happens again. But Murphy is a bitch, and I don't gamble for a reason.
    R
  11. Likes barbter, aj liked this post
  12. #8
    Jan 2019
    Arizona
    522
    34
    185
    R
    yup me too, I always wondered what would happen now I know.
    only thing that has happened to me like this is denting doors and covers and it doesnt happen alot. one reason I got collet noses.
  13. #9
    Jun 2012
    Michigan
    4,468
    4064
    2649
    Don't part it completely off, leave just a tiny bit so that you can break it off easily with your hand.
  14. Likes RJT, tay2daizzo8 liked this post
  15. #10
    Aug 2006
    2,330
    136
    543
    I like this solution the best. Won't have to fish around in the chip to find parts.
  16. #11
    Dec 2003
    poulsbo, wa, usa
    688
    30
    282
    I was running a ton of brass parts in the past and just drilled and tapped some 1/4-20 holes in the face of the chuck and made a 8" disk to cover the face of the chuck .. put three slots in the plastic disk and would center it by eye ball and tighten one bolt tight and dent the threads on the other two bolts and leave them like 1/4 turn loose so the chuck could open and close .. ran the same Disk for years ,, it keep the chips and parts from flying all over hell from the chuck jaws acting like a fan ...
  17. Likes litlerob1, lumley32 liked this post
