I know someone trying to sell 3 of them and I'm trying to help out.
2 are the older CNC 88HS control and one of them is the newer MP control.
Is there a command that will tell you?
The only options on a Fadal are hardware related.. This isn't a Haas or
Fanuc based machine where parameter 3,465,291 has to have the 8th bit turned
to a 1 to turn on rigid tapping.
The year will pretty much tell you if its an AC or a DC machine. The model will
tell you the size and if its linear or box (or a combination "A" designation).
Rigid tapping, you can tell by the e-proms on the board (you can't tell by
parameter).
If it has a hydro-sweep, your eyes will tell you.
The control will tell you how much memory it has, as will looking at
the boards.
An MP is an 88HS with a PC hanging next to it, essentially. It was
supposed to have Gibbs cam on it, but I've never messed with one..
Just something else to go wrong.
A few things to "Double Check". Sometimes a machine sold as a 2004
(or pick your year) isn't. Its a refurb, it could be an 89 or a 92 or a 97.
A lot of people selling Fadals don't realize they have the extended Z. Check
that. It would be in the parameters as a 28"Z, or if not powered you can tell
because the tool changer has a cutout in the top of the enclosure sheet metal.
There was a servo turret option at some point in the later years instead of the
geneva drive (which is Horribly Slow, how I think the 88 got its HS designation).
Some of the later later ones had a swing arm tool changer, though that is pretty
rare and VERY obvious.
4th axis ready. The basic wiring is there, on EVERY machine. But you still have
to buy a whole lot of shit to hook one up. On the flip side I've seen quite a few
that have all that stuff already there, and the people selling the machine aren't
advertising it in the ad.
There are no software options. None. Its all there, every single control can
do 5 axis simultaneous (SLOWLY), every machine can do rigid tapping with the right
hardware. Every machine has 48 fixture offsets, and a shit load of tool offsets.
Every machine is fully macro compatible.
Somebody had mentioned the spindle drive, and to me that is important. Fadals
had quite a number of different ones from the factory, and quite a lot of them
have been fitted after failure. A still supported spindle drive can be a selling
point, as opposed to one that is so old the manufacturer won't even acknowledge they
made it.
