How to create a user defined M code? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21
    Sep 2010
    india
    1,361
    75
    259
    I do not know about Haas, but on Fanuc we would store 200 in parameter 6050, for G200 to call O9010 as a macro.
    What exactly is the problem on your machine?
    Undefined G-code (O9010 not being called at all)?
    Or, some problem inside O9010?
  2. #22
    Dec 2002
    Granville,NY,USA
    3,937
    356
    448
    First enamble parameter write in setting page
    Set parameter 91 to 200
    write your program O9010 including a M99 at the end
    That should be it.
  3. #23
    May 2007
    Central Texas, West and North of Austin
    1,627
    178
    532
    Quote Originally Posted by sinha View Post
    If you do not learn, I have to be sorry for misleading you; you have to be angry, rather very angry!
    Actually, the book has been designed for those who have no or inadequate background in macro programming. If you already know enough, you may not find new things. I have considered the plight of those whom nobody is helping. I have myself gone through this stage. Mike Lynch rightly describes macro programming as "the best kept secret of CNC." (He is another author, apart from Peter Smid.)
    If you feel that the book can be improved, do let us know. Of course, if you have already thrown it in the dustbin, ....
    Sinha, I bought your book about a month ago. Only problem is getting my brain back into shape for studying out the math terms. Nothing too complicated, just some terms I don't use often and have forgotten from high school, 36+ years ago. It's coming back, slowly.
    As for being for the beginner, it is, as it takes one all the way down to the basics and starts to build from there. But that's exactly what I needed. "I know nothing and can prove it!" My main problem right now is not falling to sleep in my recliner at night when trying to read it. Not exactly a page turner, but then textbooks aren't. I sneak a peak now and then further into it and it seems to get more interesting later, but as you said, it's written to be read in order, front to back. Otherwise, you would end up bouncing back and forth looking for info that you SHOULD have already absorbed from the earlier chapters. Be like the Fanuc manual then. You've written a good book for what it's designed for. A good place to start.
  4. #24
    Sep 2010
    india
    1,361
    75
    259
    Quote Originally Posted by gorrilla View Post
    Thanks for appreciation.
    Since you already have some experience with macros, you can afford to skip a few chapters / sections, and proceed to what you are actually interested in. So, just glance through the initial chapters, to know what is described where. You may find chapter 7 (Macro Call) most interesting as well as informative. If you read the entire book, you would also know what is possible to do with macro programming, apart from basic things.
    Sinha
  5. #25
    Oct 2009
    CA USA
    186
    is it just me or is typing M98 P**** not that hard?
  6. #26
    Sep 2010
    Victoria Australia
    4,072
    1710
    Quote Originally Posted by voodoochld2 View Post
    No, its not too hard, and conventional Sub Programs have their place, but User Defined M codes offer more flexibility, particularly when used to call a Macro Program where parameters are able to be passed from the calling routine.
    Regards,
    Bill
  7. #27
    Jun 2004
    Melbourne Australia
    5,454
    Quote Originally Posted by angelw View Post
    Regards,
    Bill
    G'day Bill.
    Were you the bloke I meet in my factory here in Thomastown a few months ago, regarding a Mazak ATC turning centre?
    Regards Phil.
  8. #28
    Sep 2010
    Victoria Australia
    4,072
    1710
    Quote Originally Posted by machtool View Post
    G'day Bill.
    Regards Phil.
    Hi Phil,
    I'm the bloke!
    Best regards,
    Bill
  9. #29
    Mar 2006
    PHILIPPINES
    3,031
    1107
    1463
    Its more handy to have a G code to send
    X home
    Z center of travel
    Y to center position
    coolant off
    spindle stop
    Or a simple G code to engage C axis and get your live tooling started. these cut down on operator error.
    Thanks for the help guys.
  10. #30
    Orchard Park, NY
    85
    162
    89
    Old thread, same problem, different controller. Can this be done on a Mazak? Specifically a VTC250D/50 with a PC Fusion 640 control.
  11. #31
    Orchard Park, NY
    85
    162
    89
    Machine Parameters
    Macro Call (J)
  12. #32
    Feb 2021
    Oregon
    I bought the best kept secret book for 140 new years ago, the other book I got a used for free from an old coworker, both books are great. Definitely helped me out a lot. I still had to do research on machine variables for a lot of macros I have wrote, but definitely worth their weight in gold when starting out and learning. This are the two books I used and have created some amazing probing macros for and forgings. I have moved on from the company I wore those for, but still excited to have the knowledge and the confidence in writing some super strong custom macros that took away so much error and from making super crap. Both books I would definitely recommend for anyone who wants to learn macros and are handy references. Happy to see that they are cheaper since I bought the one out of pocket. I can understand why someone would like at least half back on their investment, but personally I like having them both for references.
  13. #33
    Jan 2013
    Louisville, KY
    3,263
    7913
    2795
    This might be the most helpful zombie thread resurrection ever. At lest this time, the subject matter is quite useful.
  14. Likes yardbird, DouglasJRizzo, mountie liked this post
  15. #34
    Jul 2013
    Indiana
    3,404
    5004
    1744
    Quote Originally Posted by Jashley73 View Post
    Absolutely! This is the exact thread I referred to when I made up my custom codes. Which parameters call which programs was definitely something I copied. I've never seen that list anywhere else.
    Brent
