Hi,
Thanks for taking the time to read my post.
I am relatively new to machining and have a problem to which I hope there's a simple answer. I am trying to turn a part on my lathe (HAAS TL-2). This is a large part (~400mm diameter). It clears the bed no problem, but it doesn't clear the cross-slide (max clearance over cross-slide is ~270mm I think).
I have a Dorian tool-post and my conventional turning tools sit on the left hand side of this, tool holder perpendicular to the Z-axis. The cutting point is more-or-less over the cross-slide so I am unable to turn any part that does not clear this.
I need to turn for a length of ~200mm so I somehow need to use a tool that sticks-out a long way to the left of the cross-slide so as to turn this part without it hitting the cross-slide.
Any thoughts/ideas would be much appreciated!
SJB
SJB
