How do you calculate this?
MazatrolMatrix
Sep 27, 2015
So I want to know how to calculate the distance from the center perpendicular to the plane that is 40 degrees from centerline. The computer tells me it's approx 61.799 mm, but I'd really like to know how to it by hand. Hopefully someone can help :)
Edit: oops sorry about the sketch there
View attachment 332213View attachment 332214
Yeah I did that, got the same result as you.
I tried to trig it out myself but I couldn't do it, which I found frustrating. Or frankly, I managed to calculate it but I didn't understand how I did it, the logic behind it, just arrived at the right conclusion somehow since I already knew the answer. Would really like to learn how to solve it by hand.
Your hankerin for smarts is admirable! But don't feel bad, lots of us rely on the magic pixie thinking boxes for this stuff. I know I do!
I was a straight A student in math and geo/trig in high-school (34 years ago). I could have figured that out lickity=split back then.
Now? Nope! I haven't used those cerebral compartments in so long, the lights wont turn on any more.
I work in imperiel, so I converted your numbers to the 5th decimal, and came up with 61.79832
extend the 40° line to where it intersects with the centre line by constructing a triangle from the 38mm flat.
You then are left with a single triangle that you can calculate the length you require.
Haha, thanks. Well, I really think there's value in trying to calculate things yourself instead of just relying on software all the time. Sort of like studying for a test and memorize the questions, maybe you pass but did you really understand it, did you really learn anything. If anything it feels good to know how things are done!
Thanks alot Gregor!
You're welcome.
Note that is only one way. You could just as easily split the four sided area up into two triangles with a line from the centre to the corner of the 38mm flat and do it that way. Basically any way that you can find to split it up with two right angle triangles and you're basically done.
You're welcome.
That's how I was going to do it at first, but when I started my little sketch, I changed my mind..
Just because.. Not because one way is better than the other.
And yeah.. Solve one triangle (that you have to make up).. some addition, and that gives you the hypotenuse
on your second triangle, and that's your answer.. I got 61.79973373.
I enjoy these threads.. Every once in a while its nice to find out I still remember how to do the math.
You're welcome.
I tried to calculate it but I ended up with 68,82. The correct answer is 61,799. Must still be something missing!
Oh, never mind! :scratchchin:
Look at the skinny triangle first. 19mm and 73.5mm dimensions are known.
(1) Solve for the hypotenuse: C^2 = 19^2 + 73.5^2
Google: sqrt(19^2+73.5^2) = 75.916
(2) Solve for the angle: tan(x) = 19/73.5
Google: arctan(19/73.5) to degrees = 14.494
(3) The 50 degree dimension is known. Use this to find the angle of the bigger triangle.
50-14.494 = 35.506
(4) Solve for the distance to centerline: cos(35.506) = x / 75.916
Google: cos(35.506 degrees) * 75.916 = 61.7998
Is it me or did something change in this post?
The 19 or double comes from where and the 73.5 line did not look square to the world but it is now gone.
Wonder the most complicated way to solve or most math.
Sketching it in CAD is surely cheating.
The 38 at the top.. And the 147 WAY over on the right.. Of course we all just
Ass-U-Me'ed that everything was symmetrical.
It looks a little wonky, pic of a monitor from a bit of a high angle.
The most complicated way?? I'm sure you could create enough geometry off of that to
make the math take you the rest of your life.. You could put in a 3 point tangent circle,
and then come off of that to calculate your distance.. That would be complicated, and
a bit stupid.. But.. eventually.. it would get you where you need to go.
50-14.494 = 35.506
Thanks for that 👍
Lets do it the easy way.
Point on the line is -19 x and 73.5 y.
If one had to measure it on B-port rotary table or surface plate you would twist it so the line straight.
This simple.
One sine and one cos is needed. No need to solve the other axis.
Triangles are great but sometimes easier to rotate the world around zero.
This simple.
In this case it was necessary for programming purposes.
