chip_maker
Stainless
- Jan 14, 2006
- Moira, NY USA
Moving my shop and getting machines powered up at new shop. Having a problem with my 97 vf-2.
Powered it up and I got a dead crt. Machine will go through the power up re start routine and I can jog the axes and change tools using the atc f/r buttons.
Now when I initially powered it up I heard a little snap crackle pop and caught a whiff of the magic smoke .
The machine will not run a program or make any commands in mdi work. I'm doing all this in the dark, but I know my way around the control even when I'm "blind".
On these older haas's how can you tell if it's properly phased? the newer ones have an led that'll let you know if you need to swap 2 wires.
Any idea what the problem is before I make a service call?
