How on earth do you open the back cabinet on a Hardinge GT27??
Results 1 to 13 of 13
    Oct 2014
    CANADA
    Ontario
    1,141
    643
    870
    Question How on earth do you open the back cabinet on a Hardinge GT27??
    Hey guys,
    Dumb question I know, but I cannot work this out. I have released the panel latches top and bottom on the rear cabinet door, but the main power switch has a connection going back into the cabinet which still prevents it from opening... I'm sure there's a simple trick to it but I haven't yet worked it out!
    All help appreciated so I can start getting this machine all cleaned up!
    Aaron
    Jul 2006
    Arizona
    4,558
    18357
    4297
    There should be a Phillips or flat bit screwdriver hole in the breaker handle. Turn it with a screwdriver and the door should open. This is a safety device to keep you from opening the panel when the breaker is turned on.
    You should not need the screwdriver if the breaker is turned off though.
  3. Likes aarongough liked this post
    Oct 2014
    CANADA
    Ontario
    1,141
    643
    870
    Interesting! I'm sure I tried it with the breaker turned off (power is not connected to the machine right now anyway) but I will double check when I'm in the shop tomorrow, perhaps I was just having a 'slow day' when I last tried!
    Thanks mate!
  5. Likes Philabuster liked this post
  6. #4
    Oct 2009
    Oregon
    4,092
    4388
    2055
    I have a late model Pacemaker lathe like that. Took me a minute to figure it out. The screw is easy to find, but it isn't labeled that you have to turn it to open the door.
  7. #5
    Mar 2011
    Geneva Illinois USA
    6,050
    2531
    2347
    There may be a problem with the enterlock if the breaker was in the off position. Some may require that the handle be moved to the reset position for it to be disabled.
    Tom
  8. #6
    Oct 2005
    14,562
    Quote Originally Posted by TDegenhart View Post
    Tom
    Yup, and when all else fails "jiggle it" whilst pulling on door.
  9. Likes TDegenhart liked this post
  10. #7
    May 2019
    223
    44
    66
    On my OKK you have to turn the power disconnect counter clockwise to the reset position to open the doors. This is a momentary spring loaded position. As others have mentioned above.
  11. #8
    Feb 2006
    Republic of Texas
    2,452
    Quote Originally Posted by Hardplates View Post
    I've got one machine like that: Turn power off and turn a little more and latch inside trips and door can be open. There is a small hole in the switch mount that I can stick a small screwdriver in to open the door when power is on.
  12. #9
    Feb 2014
    Sunny South West Florida, USA
    2,703
    10335
    3120
    This'll do it.
  13. #10
    Oct 2005
    14,562
    Quote Originally Posted by TeachMePlease View Post
    This'll do it.
    Once.....
  14. Likes TeachMePlease liked this post
  15. #11
    Feb 2014
    2,703
    10335
    3120
    Once.....
    He never said he needed to close it again
  16. Likes Milacron, NAST555, Philabuster liked this post
  17. #12
    Jan 2019
    Missouri
    89
    25
    11
    make sure the 1/4 turn latches are actually released, just pull on the corner and compare one position to the other. These latches can become inoperable.
    The factory main disconnect on the GT is different than jap machiness. The mechanical door interlock override is a slider that you pull down on with a flat blade screwdriver. In a clockwise fashion for about 30~45 degrees. It is easy to overlook, not a hole.
    The control cabinet can only be opened if you first open the main electrical cabinet. There is a tab on the door.
  18. #13
    Oct 2005
    14,562
    Yup, that spray painted giant Red "X" probably means "Scrap this machine".
