How this feedrate Vf been calculated ?
NzNacer
Jan 7, 2015
Biskra, Algeria ,Africa
Hi there ,
Chip thinning is new term for me , I'm old school machinist ,
Feedrate formula is Vf= N*Fz*Number of flutes or teeth
N=Rev par minutes
Fz= Tooth load
I want to know how these guys applied chip thinning to this work (see pic)
Thanks AtomKinder fro responding :)
I have red the article you gave me , it s very informative , please be patient with me
let's say i have 0.05 chipload par tooth and i want 30% redial engagement of the tool what I should do is 0.05 *(chip thinning factor given by the tool manufacturer ) let's say 1.091
new chip load = 0.05*1.091
Yes that would be correct. Also keep in mind that much of this, like recommended chipload from the manufacturer, is a starting point only. Different geometries will affect what sort of chipload is feasible, as well as considerations such as machine acceleration capabilities. I have found that generally HSM is much safer with regards to tool life as well, making roughing operations very predictable IE watching the chips is a very good indicator of tool wear.
Edit: as a reference, one of my favorite test parts runs a 1/2" 6-flute end mill (12.7mm) at 8828 RPM and 296 IPM (.00559"/.1419mm per flute), 10% stepover. And that's a conservative chipload.
