How to measure the radius of a boring bar - Page 2
Results 21 to 40 of 42
  1. #21
    Nov 2002
    3,242
    1818
    800
    Quote Originally Posted by Finegrain View Post
    Quite a challenge to measure ANYTHING +/-.001mm,..... then push on the tool with your hand and watch the indicator move . Now re-evaluate the utility of making your +/-.001mm measurement.
    You want to measure/ qualify your boring setup to 0.0000393"
    I would guess that even attempting to get within 0.01mm prior to using it in the machine, will be tough.
    Best of luck!
  2. #22
    Apr 2013
    West Virginia
    59
    31
    Quote Originally Posted by G00 Proto View Post
    Take a picture of the setup using your iPhone. Then email it yourself. Import the picture into Solidworks (or any cad cam system). Then draw a centerline down the center of the boring head, and a point at the tangency of the cutter radius. Then set your CAD measuring increments to .001 mm (actually to be ISO, you need to set the increments to .0001 mm). Then simply pull a measurement from centerline to the point. That times two will give you a measurement to the nearest .001 mm.
    You’re never going to get anywhere near .001mm with a photograph. Even if you had the camera in a copy stand capable of that level of accuracy the actual camera isn’t that close to parallel to the body of the phone. Parallax at just 30mm away from the object being photographed will push you outside the requested spec.
  3. #23
    Nov 2013
    Utah
    4,374
    1170
    2399
    Quote Originally Posted by IrritableBadger View Post
    He was joking dude.
  4. Likes G00 Proto liked this post
  5. #24
    May 2013
    wi usa
    193
    60
    Good question, I also kinda wondered that over the years.
    We have fancy automatic tool measuring machine at work. It cost more then my house.
    We still go small and adjust to size. The material, machine differences, setups, speeds and feeds can push hole sizes all over the map. Never had one come off of pre-setter and do perfect hole yet.
    I was taught to test bore on small side and adjust final size from there.
    In my home shop for race engines, I just made up perm set boring heads to my common bores sizes.
    They were all set by going small and adjust to final size.
    I always then try to finished honed bores to +-.0002 or better.
  6. #25
    Nov 2014
    Colorado
    2,719
    3231
    717
    He was joking dude.
    I thought it was pretty funny...
    I'll have to re-read all these posts.
    I know a few old school handy high-precision "Peeps" use analogue microscopes over the tip of a tool mounted on an open machine (like a lathe). Where you can easily see the curvature of the radius of the tip of the tool relative to cross hairs, and with a graticule "fit" the radius.
    I also know from various physics experiments ( old school) that you can have horizontally travelling microscopes (mononcular) on a precision straight track/ stage + scale. Maybe with DTI and gauge blocks , micrometer screw … translation/ translating the microscope accurately that critical dimension can be found. [Other than taking a test cut as some have wisely said.].
    I know that's very vague but pretty sure it can be done... shop microscope that can mount to machine or go in spindle (like a Bridgeport) that some have used in the past might get it within a tenth/ two tenths .
  7. #26
    Jan 2007
    Flushing/Flint, Michigan
    7,601
    378
    6350
    I wonder what you could resolve to on the latest phone camera given this field of view?
    Telecentric optics would be nice but you can partially correct in the soft side for distortions.
    At one micron and white light there are other problems but how about a few microns.
    A add on lens?
    When I started in "camera measuring" we had 256x256 sensors... yea a whole 64k.
    Bob
  8. #27
    Feb 2013
    Idaho
    654
    132
    711
    He was joking dude.
    I figured someone would bite on that one
    In all actuality, I kinda wonder what someone could do with a real vision system mounted in a machine. In theory, you could spin a boring boring bar in the spindle and have good enough resolution to pick up the tangency point on opposing shadows. Of course this completely ignores tool and part deflection.
  9. #28
    Nov 2014
    Colorado
    2,719
    3231
    717
    A add on lens?
    When I started in "camera measuring" we had 256x256 senors... yea a whole 64k.
    Bob
    That's a good thought / thoughts.
    Telecentric lenses are really expensive.
    It is possible to calibrate the snot out of more regular lenses for radial and tangential distortion as well as magnification and principal distance (effective focal distance) + principal point (intersection of optical axis) with sensor as well as determining the rear nodal point of an imaging (perspective center) or point of projection.
    That's kinda my day job / part of the systems I have to roll out.
    There is an neat old school photographic trick is that you can reverse the lens (there's special mounts for that) … So you can image near microscopic objects, (different from a lens extension for macro stuff).
    If you are not doing photogrammatery then regular images suffer from what's called relief displacement... Objects at different heights and distance radially displace away from the perspective center of an image. Think of aerial photography of sky scrapers in New York (camera pointing down) the tops of the sky scarpers radially displace away from the bottoms of the shy scrapers relative to the principal "center" point on the photograph, that's WHY photographs typically are not "Planimetrically" correct.
    There's a lot you have to do to make imagery "Metrology" grade (that's one of the things I do / engineer).
    HENCE your suggestion / general use of Telecentic lenses (it's sort of an industrial hack that works for some situations especially if everything is on one plane.
    TRUE TRUE about diffraction effects of light around edges (like a tool point or sharp edge) [Well done / thumbs up (without being patronizing.). ].
    Phone cameras are weird beasties and there's a LOT of digital processing also that kinda makes some metrology a bit invalid.
    Some of the stuff we do we can fit accurately to an 1/8 th of a pixel / "Photo element".
    On some Medium format sensors that are roughly 10K by 6K "Pixels" … 60 Million + pixels on a bayer sensor.
    Each pixel / photo site is approx. 5 microns each. With the right optics and monochromatic light you can certainly image down to one micron.
    But overall the cheaper easier approach is translate (mechanically) $20 webcam hooked to a microscope. The effective long narrow angle view is repeatable when translated.
  10. #29
    May 2011
    New Jersey
    1,923
    173
    1043
    Dial it in and send it!
  11. Likes cameraman liked this post
  12. #30
    Nov 2014
    Colorado
    2,719
    3231
    717
    I think three dimensionally there's a lot that can be done more generally especially for 5 axis snafuu prevention. With cameras placed variously in the machine capturing three dimensional information real time.
    ^^^ Check this out , kinda relevant to Op's question , (the music is beyond stupid and distracting worth turning off lol ).
    But I LIKE the 5 axis calibration routine and corrections thereof through test cuts verified in process to converge on the most probable fit for that machine (i.e. better kinematics + process)…
    Need to watch this again,
    COOL with what I would call a dynamic fixture that the spindle could be used as a ROBOT with an Allen head / socket head and make computed adjustments on the specialized fixture plate (+ rotary table moving to new positions for adjustment / access to mechanic adjustments made by the spindle with hex socket tool) .
  13. #31
    Apr 2013
    West Virginia
    59
    31
    It was fairly well written and I really thought it was someone grossly overestimating the power of their phone. The ISO compliance should have tipped me off I suppose. Alas, I was taken in.
  14. Likes G00 Proto, litlerob1 liked this post
  15. #32
    Feb 2013
    Idaho
    654
    132
    711
    All in good fun, thanks for being a good sport.
    It is astonishing how often I take a picture of something with my cellphone and import it into CAD. Then I diligently draw lines, splines and arcs around the often times hand carved part to make a solid model. So much so that I've gotten scientific and use a tripod for perpendicularity and use a 6" scale to get the aspect ratio correct... I figure I can hold plus or minus .030" but I might be optimistic
  16. #33
    Jan 2014
    Washington
    4,408
    805
    2374
    .....I take a picture of something with my cellphone and import it into CAD. Then I diligently draw lines, splines and arcs ....
    The modern take ^ on how to convert old PCM drawings to CNC programs. Sure beats my old method of laying the PCM over graph paper and plotting points, estimating radii, and arc centers from that.
  17. #34
    Feb 2013
    Idaho
    654
    132
    711
    You're bringing back nightmares of using Mylars… now that was fun.
  18. #35
    Feb 2014
    Sunny South West Florida, USA
    2,699
    10320
    3118
    So they actually make this vision system for centering tools in a Swiss lathe, which isn't identical, but shows what you can do with a good vision system in the machine. I had a demo in my shop. Neat stuff. Not worth it to ME, but not worthless, either.
    Perfect Zero Visual Alignment System - GenSwiss
  19. #36
    Apr 2013
    West Virginia
    59
    31
    I’d like to see a tilt/shift lens for phones, like they use for fine art and architectural photography.
  20. #37
    Nov 2013
    Utah
    4,374
    1170
    2399
    There are phone apps, to "tilt/shift" images. But I think an actual lens might be asking a little much of my phone. I hate all the cell phone BS though, so the resentment might be bleeding through.
    R
  21. #38
    Sep 2015
    CANADA
    Ontario
    92
    43
    35
    FWIW I used to run a FLOW waterjet at an old shop and the software it came with had a function called "rasterizing" where it could draw lines and arcs over the gradients in a JPEG photo.
    It wasn't perfect but it worked pretty damn good and if you can find something similar it can save a lot of time when you need to do this kinda thing
  22. #39
    Feb 2013
    Idaho
    654
    132
    711
    Quote Originally Posted by 007Rob View Post
    Unfortunately, rasterizing either in cad cam or in Photoshop yields unsatisfactory results for what I’m doing (same with digitizing). I am generally transitioning a prototype concept into something that can be machined in high volume. By the time I’m done with the cad model it needs to be fully defined and resolved as a solid model that can be opened with no errors by any cad system in the world. It sounds a lot more fun than it is
  23. #40
    Nov 2013
    Utah
    4,374
    1170
    2399
    If I remember right Mastersuk V9 still had "rasterizing". When they switched to X in like "98? they got rid of it.
    R
