How was this Mirror finish achieved on stainless?
Results 1 to 15 of 15
    Jan 2018
    Lightbulb How was this Mirror finish achieved on stainless?
    How was the finish done on this stainless steel "screw"? It a mirror finish. Im not sure what type of stainless or if is indeed stainless at all. Its pretty heavy, definitely not aluminum, although it does have two aluminum clamps inside of it attached with three bolts. I have seen knife makers like John Grimsmo polish a knife to a mirror finish. Any input?
    Jan 2018
    As you can see the inside and bottom were not finished with a mirror finish because it is not required as they will have nothing in contact with them so friction is not an issue. To the contrary of the smooth outer side where it will have foam cups sliding on them and minimal friction is required hence the mirror smooth surface.
    Sep 2008
    1,062
    675
    604
    i would start with progressively finer grades of wet and dry, finishing with 1000 grade, then either polish with a buffer wheel, or use polishing compound with a rag.
    If it was turned then it would be relatively straight forward to get a good polish. A milled finish would take longer. Also if you have to maintain a tight tolerance that will dictate how much material you can remove before polishing starts.
    Jan 2009
    "Stuck in Lodi", Ca
    3,114
    1842
    1618
    I recall seeing some parts that somewhat hand finised to a resonable point then they were "Electropolished". If my memory serves me correct that was the term used. It's kind of like reverse electroplating. There was final polising afterwards.
    Langley, B.C.
    1,331
    247
    754
    Any place that does chrome plating could easily polish that--much easier than doing it yourself. That "might" be electropolish
    but I think it's a bit too bright...
  6. Likes digger doug liked this post
    Nov 2013
    Utah
    2,553
    704
    1364
    Looks Chromed to me. Not to say you can't get there without, but that would be the easy(not necessarily cheap) route. I would try to get a hold of the print to see exactly what material it is. I can tell you it ain't 12L14 or 1018 or A36.
    It seems like an obvious Turning job to me, but lately the Mill guys around here seem to think different.
    17-4, 304 and 316 finish absolutely beautifully. With a Wiper insert, high SFM and slow Feed I can get a finish pretty damn close to that right off the machine, with those SS's. I have achieved a 4µin. per the Profilometer.
    R
  8. Likes Vancbiker, Cycle1000 liked this post
  9. #7
    Jun 2015
    CANADA
    British Columbia
    1,054
    241
    553
    Electro-chemical or chemical polishing leave a shiny finish but not precise surface. It is mostly used for decorative, food industry, high vacuum, high voltage - for parts that need polished surface but not perfect mechanical or optical accuracy. Buffing will have a similar effect. If both accuracy and finish are needed, it can be done by fine machining or grinding and then lapping - for example ball bearings.
  10. Likes digger doug liked this post
  11. #8
    Oct 2016
    UNITED KINGDOM
    41
    5
    16
    That looks electro-polished to me
  12. Likes aj liked this post
  13. #9
    Feb 2007
    Aberdeen, UK
    2,929
    1041
    1013
    Quote Originally Posted by billzweig View Post
    Dimensional change from electropolishing depends heavily on initial surface roughness. It removes the high spots, so rough finish = significant dimensional change.
    We make some parts out of 17-4 that have close tolerances that are electropolished after machining. As long as the surface roughness out of the machine is in the 0.2-0.4µm ra out of the machine, then the dimensional change during polishing is in range of several µm only.
    OP's part certainly looks similar in finish to our 17-4 parts after electropolishing.
  14. #10
    Nov 2002
    3,087
    1443
    670
    As others have said, it is probably electropolished.
    With the exception of the fin at the bottom, it could also have been burnished as the final step in the turning process.
  15. #11
    Jan 2014
    Washington
    3,036
    581
    1529
    ......17-4, 304 and 316 finish absolutely beautifully. With a Wiper insert, high SFM and slow Feed I can get a finish pretty damn close to that right off the machine, with those SS's. I have achieved a 4µin. per the Profilometer.
    I think this is pointing the right direction.
    One screw machine place I installed several Citizens at would routinely do an 8µin finish as turned in stainless. Feeds were sometimes as low as .0002" per rev when cutting a .04" diameter.
  16. #12
    Aug 2006
    Wisconsin
    1,510
    644
    569
    Looks like a diamond polish to me. Any mold shop can do that on almost any material.
  17. Likes Greg White liked this post
  18. #13
    Dec 2008
    New York
    8,536
    2275
    certain carbide inserts leave a shiny finish when sfpm is high enough and ipt is in the minimum range often .0030" ipt
    cratex rubber abrasive sticks i hold in plastic hand holders (same used for abrasive stick polishing of molds) and hold against part spinning in a lathe. if acts like a rubber eraser and smooths finish. they come in coarse, medium, fine
    also just using a buffing wheel parts can be hand held against to make shiny. the softer the abrasive the more it blends corners or effects shape, profile, tolerances. the harder it is the more it will true up the profile. just saying if cosmetic finish usually do not worry about removing .0005"
  19. #14
    Aug 2013
    Chicago, IL
    618
    421
    239
    Abdat60 - It looks a bit "cloudy" to me, like a foggy mirror...is it? If so, that would be vibratory finishing...different cutting/polishing medias used with different pastes/additives can smooth out machine marks and even shine them up like what I think I see. I do not think you can achieve a "perfect" mirror finish with that process but if it looks like there are microscopic dings a smudges on it when you look closely that could be your scumbag.
  20. #15
    Dec 2008
    New York
    8,536
    2275
    Quote Originally Posted by Nerdlinger View Post
    i have seen shiny surface where you could see a tape measure in reflection but not like you can read the small letters in reflection
    buffed parts often a object with zebra stripes is held and you look at reflection to see how straight the zebra stripes look in the reflection. if distorted its cause part is not perfect or distorted
    picture buffing to mirror finish
