How to operate Harrison 400 with Fanuc cotrol (alpha)
Likes Likes:  0
Results 1 to 9 of 9
    Apr 2019
    EGYPT
    Default How to operate Harrison 400 with Fanuc cotrol (alpha)
    i know all thing but i still have not any idea about Op . no
    and how to input a program from Rs232 to machine
    css and how to activate it
    Jan 2017
    Oregon
    2,080
    398
    1549
    Op no. is just the program number. Starts with the letter "O" and has 4 numbers, like O1234.
    Assuming the control is newer than a 6T, if the control is set to receive programs via RS232, loading a program is done in edit mode with the softkeys: O1234 <read> <exec>.
    CSS is called by G96, as in G96 S400 M03. That will set cutting speed to 400 sfm. You turn it off with G97- so G97 S400 M03 will set the spindle to 400 rpm.
    Jan 2014
    Washington
    4,062
    761
    2143
    Some of the Harrison lathes used a Fanuc PowerMate or QuickPanel for the control and some funky Harrison built data entry panel. I "think" gregormarwick" on the forum has some experience with these. Maybe he will chime in.
    @OP, would you post pictures of your control panel so we will better know what your control system is.
    Apr 2019
    EGYPT
    Quote Originally Posted by jancollc View Post
    this is when i click on op no and click EDIT
    whats shall i do ?
    send the file first and then enter edit ? or what
    Jan 2014
    Washington
    4,062
    761
    2143
    What you have there is a unique Harrison implementation of a Fanuc motion controller. Hopefully someone with experience on this particular Harrison setup will see this thread and try to help.
    Apr 2019
    EGYPT
    thanks i only need to send any program nc to the machine via port rs232
    wait any help
    Dec 2002
    Benicia California USA
    7,847
    1729
    2206
    There are two different setups for the
    "Harrison Alpha" lathes.
    One has a standard Fanuc (21i) control that behaves as a normal Fanuc control as to input and output and programming.....
    Additionally there is a second operating system that is user select able. That runs the "Alpha" operating system, with the Fanuc running behind.
    Not an expert here but i believe the Alpha setup is really designed for user input at the keyboard (MDI)
    There is an RS232 interface , but I think the Alpha side will only accept its own unique code ...Harrison did offer offline programming tools (CAM) that would output the Alpha code....
    Unfortunately, your machine appears to be the second Harrison "Alpha" setup..that is it only has the "Alpha " operating system.(can't run in native Fanuc)..which means ,i believe, that you can only import or export
    native "Alpha" code to the control....Which really leaves MDI as your primary programming mode.....
    Perhaps someone with more hands on experience will add to this....
    Cheers Ross
    Feb 2007
    Aberdeen, UK
    3,326
    1174
    1239
    Quote Originally Posted by yurirevenge View Post
    whats shall i do ?
    First, the only way to send programs to the alpha is using the alpha-link software that Harrison originally supplied with this machine.
    If you don't have it, you can acquire a copy from SuperDraft in the uk. It's not too expensive.
    Next, there are two types of data you can transfer between the computer and the lathe: manual ops, which is what you are looking at in your pictures, and cam which is a basic cam program made in alphalink and transferred to the lathe by pressing the cam softkey.
    Apr 2019
    EGYPT
    Quote Originally Posted by gregormarwick View Post
    no another program can i use it for free istead of alphalink ???
