How to Purposely Leave Grooves Using Face Mill/Fly Cutter
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Dec 2019
    43
    16
    Default How to Purposely Leave Grooves Using Face Mill/Fly Cutter
    Hi Guys,
    This is for a golf putter application. I've got a Kennametal Mill 1-10, 90* inserts with a 0.007" corner radius. Been playing around with different feeds and speeds, trying to leave grooves in the 0.005"-0.010" deep range, about 0.020" apart. I'm currently testing with only one insert on the face mill to make things simpler. I've tried various spindle speeds from 450-900, with corresponding feed rates of 12.3975ipm to 24.795ipm, with DOC's from 0.005" to 0.050". The best I can do is leave visible marks in the pattern I want, but nothing deep enough to feel. Effectively, the face mill is doing exactly what it's supposed to, just not what I want it to do. Currently testing on 6061 with MQL, but end application will be 316 and 11L17 (leaded low-carbon steel). Any advice from experience would be greatly appreciated! I've attached a picture of the desired end result, plus the insert specs. I haven't gone the fly cutter route yet, as these inserts seem to be pretty dang close to what I'd make for a fly cutter anyways (which would be totally new territory for me).
    May 2005
    CA
    1,161
    10
    307
    Is the face mill large enough diameter to make it across the full face with the "leading edge" before the trailing edge comes across and wipes away your work?
    Oct 2006
    New Hampshire
    207
    86
    54
    I’ve done that finish in 6061 with one of these
    B-52 Fly Cutter - Kristi Tool
    The bigger spacing grooves I would just use an engraving tool
  4. Likes sdinzy, Garwood liked this post
    Jun 2012
    Michigan
    5,097
    4655
    3072
    Use an engraving tool.
    Personally I don't understand the fascination with this new fad of leaving machine marks on golf clubs.
  6. Likes sdinzy, DanASM, TheOldCar liked this post
  7. #5
    Jun 2019
    396
    124
    347
    Quote Originally Posted by sdinzy View Post
    Hi Guys,
    I've done it before but not intentionally. Just forget to put a G01 after a G00 and you'll have your pretty little swirly marks. To make it easier take all but 1 insert out after facing.
  8. Likes TeachMePlease liked this post
  9. #6
    Nov 2014
    Florida
    4,352
    1687
    2069
    Quote Originally Posted by Mtndew View Post
    Personally I don't understand the fascination with this new?? fad of leaving machine marks on golf clubs.
    I have a scotty cameron putter ca. 2000's that has very much what OP shows in the pick, not exactly the same, but you want some roughness on the face.
    OP, you will not get what you want with a face mill (the large/deep grooves), but if you run the feed fast and rpm slow you will get some roughness on the face.
  10. Likes sdinzy liked this post
  11. #7
    May 2005
    CA
    1,161
    10
    307
    I don’t believe there will be a way to make a consistent pattern (as in your example photo) with a face mill unless you can synchronize the spindle with table travel/position.
    Is machining in the pattern with a ball end mill out of the question?
    PM
  12. #8
    Feb 2004
    Staten Island NewYork USA
    3,841
    1143
    1884
    Fly cutter set to diameter...
    Locate-plunge,retract.
    relocate- plunge, retract
    New flycutter, new profile with new diameter
    The reason for the fad is its new...and a fad.
    Ask a golfer, they'll offer up some reason...but as long as they are buying, ask me if I care.
  13. #9
    Dec 2019
    43
    16
    I've done it with an engraving tool, it's just not as authentic as the real thing, which is indeed done with a fly cutter. The circles that are spaced farther apart are definitely done with a ball mill. Looks like I may have to get a fly cutter. Thanks BALLNH!
  14. Likes BALNH liked this post
  15. #10
    Jun 2012
    Michigan
    11,319
    3876
    3994
    One might use a single point fly cutter with the shape of a 60 (or a 30*)included thread form with a .020 radius. Mill across .020 deep with a .040 feed-per-revolution to make the close marks as this would leave tool marks..…then with .040-.050 deep travel across with a 1"‘ feed per revolution. going right , then going left.
    Yes few mills would not have such a high feed rate, so moving across above the part and then plunge down at each 1” going right , then the same going left. Plunge at each 1" spot,long travel free/above between each plunge..
    Yes the cut arc would the diameter the fiy-cutter is set.
    Once you git the feel for this it would go very fast.
    Yes likely play with feed and depth until you get the look you like.
    Back in the 60s I did a few like that with using a diamond cup wheel using a tool and cutter grinder for carbide golf club pads. Yes that took more time than it was worth so I only did a few. Nowadays with a CNC machine it would be quick work.
  16. #11
    Dec 2019
    43
    16
    Quote Originally Posted by BALNH View Post
    What kind of insert did you use to get the grooves, what kind of corner radius? Kristi doesn't make a B-52 in the size I need (1.25"), so I'm going to have to figure out another product.
  17. #12
    Jan 2007
    Flushing/Flint, Michigan
    8,647
    466
    7103
    That insert will not make the grooves you want due to it's trailing flat. You would have to notch the trailing flat leaving only the radius.
    A TPG cutter with a small radius might. Something that uses a VPxx might be better yet.
    As said above the plunge and move method is going to be best for the deeper circles.
    You need a pointy tool.
    Bob
  18. #13
    May 2019
    Michigan
    876
    94
    334
    Wait...you started the thread about the chopped-up aluminum finish.
    Just put the old TPG tool back in the machine and start a NEW FAD!!!
  19. Likes TeachMePlease, mmurray70, mountie liked this post
  20. #14
    Jan 2007
    8,647
    466
    7103
    I think the OP does not want a scattered or by luck finish.
    This in the domain of controlled, measurable and repeatable.
    One should be able to run SPC on this face and hold it day in and day out.
    Bob
  21. Likes sdinzy liked this post
  22. #15
    Dec 2019
    43
    16
    Haha yep! I know right, to bad I literally threw it away *facepalm*. I was just thinking that that tool with some different inserts would have been perfect, ugh.
  23. #16
    Dec 2019
    43
    16
    Bob
    Exactly Bob!
  24. #17
    Feb 2004
    3,841
    1143
    1884
    Why buy a fly cutter. Get a piece of stock and mill a slot with one edge on center for a tool bit. HSS carbide or insert, couple set screws and your done.
    Or buy the 3 piece fly cut set...think its about $20. But then you have to wait...
  25. #18
    Sep 2002
    People's Republic
    4,394
    421
    2684
    The fine marks were probably done with[or could easily be done with] a fly cutter.
    The heavy marks are engraved. I really cannot see doing the plunge move repeat with the head tilted or whatever, be easier to interpolate it
  26. #19
    Aug 2005
    CT
    7,922
    342
    1941
    The problem with a flycutter on a well squared VMC is that you will bet bidirectional toolmarks.
    However ...
    put the same tool on a Bridgeport, cock the head by a 1/2deg .... Voila!
    With power feed, it will be consistant and repeatable.
  27. Likes neilho liked this post
  28. #20
    Jan 2007
    8,647
    466
    7103
    The fine marks are feed per rev and done with head nod or running uphill on square VMC (Z+ feed). One can see that in the edge to center widths.
    Both methods leave only the leading edge.
    The deep grooves are plunge circles. Note how they line up.
    Bob
