How to Purposely Leave Grooves Using Face Mill/Fly Cutter - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    Oct 2006
    New Hampshire
    207
    86
    54
    Quote Originally Posted by sdinzy View Post
    What kind of insert did you use to get the grooves, what kind of corner radius? Kristi doesn't make a B-52 in the size I need (1.25"), so I'm going to have to figure out another product.
    I think this is the insert I use for 6061
    https://www.mscdirect.com/product/details/52738218
    I can check the box on inserts when I get to work Monday. I did it on a VMC.
  2. #22
    Jun 2012
    Michigan
    11,342
    3882
    4004
    I used to diamond checker them on the surface grinder with a parting wheel and a set of lay down angles.
  3. #23
    May 2005
    CA
    1,161
    10
    307
    Quote Originally Posted by SIM View Post
    Fly cutter set to diameter...
    Locate-plunge,retract.
    relocate- plunge, retract
    So obvious, I couldn't even see it! Thanks for posting that SIM !!
  4. #24
    Feb 2013
    Idaho
    755
    171
    868
    Quote Originally Posted by precisionmetal View Post
    I just use a drill cycle with any old face mill... makes it very simple to control. Only works if your facemill is big enough in diameter (or you get the corresponding frowny face cut with the other end of the cutter). If that is the case, you can either tilt your part on a 4th or 5th (PITA), get hinky with design to have both smiles and frowns, or just engrave using a ball endmill.
  5. #25
    Dec 2019
    43
    16
    The fine marks are feed per rev and done with head nod or running uphill on square VMC (Z+ feed). One can see that in the edge to center widths.
    Both methods leave only the leading edge.
    The deep grooves are plunge circles. Note how they line up.
    Bob
    I’m working on a 5-axis Haas, so it is definitely square. What do you mean run uphill?
  6. #26
    Dec 2019
    43
    16
    Quote Originally Posted by BALNH View Post
    That would be great, thank you. Did you have to modify the inserts at all? As you know, I’m an insert noob, but doesn’t the trailing edge (flatter part) smooth out or wipe the surface? I’m wondering if I should file that part of the insert?
  7. #27
    Jan 2014
    Washington
    5,083
    915
    2737
    relocate- plunge, retract......
    Like G00 posted above....
    G82 will do this and make for a short program using an incremental loop for the locations.
  8. Likes Booze Daily liked this post
  9. #28
    Sep 2006
    Abingdon, VA
    3,488
    4717
    3330
    The small grooves look and work great, but I’m not too sure about the larger grooves...?
    Appears if one of these grooves contacts the ball first, it could start the ball off-line... ??
  10. #29
    Jan 2007
    Flushing/Flint, Michigan
    8,660
    467
    7108
    From your other thread you already have the cutter body but not sure it is the right diameter to make your desired circles.
    With a standard and small radius insert the trailing flat will never touch. What you do not want is these inserts which you have on hand:https://www.mscdirect.com/product/de...rItem=78231982
    That is a wiper flat on the corners, you want a nose radius to match the size in those big grooves.
    Lay it out in a CAD, if the radius size vs depth is large you may hit the back 60 giving you a groove with a bit of a back angle in which case you need to go with a "V" insert and body,
    In a uphill run the part is mounted at a slight angle in the vise. Then the program is written to climb that angle.
    This way the back side of the cutter is always in the air leaving only the marks from the leading side.
    Note that this or head nod in B-port leaves a not perfectly flat surface (concave), The amount dependent on cutter size and tilt so don't get carried away.
    You want the trailing edge of the cutter to just miss the highest point of the cusp from the guys up front.
    Bob
  11. Likes Chris Attebery liked this post
  12. #30
    Feb 2004
    Staten Island NewYork USA
    3,842
    1144
    1885
    ...call me Captain Obvious.
    With all the talent here on this site your bound to come up with a good method of doing almost anything.
    Glad it might help.
