How ridgid is the haas tm3 mill
Page 1 of 2 12 LastLast
Results 1 to 20 of 38
    Feb 2016
    New York
    28
    Default How ridgid is the haas tm3 mill
    Are these haas tm3 mills ridgid and good enough for working with tough stainless steel? How would you compare them to an old ridgid bridgport mill cutting tough materials?
    Dec 2008
    New York
    9,222
    2389
    Quote Originally Posted by Sure View Post
    bridgeport series 1 mill with 1.5hp motor i find when using much more than 1 hp it vibrates or chatters a lot. in general i look at motor hp. they dont usually put too much bigger of a motor than the machine can handle
    obviously at slower rpm the cutting forces are higher. literally cutting the same cubic inches per minute if you go 100 times slower sfpm that the cutting force is 100x higher.
    Nov 2002
    3,169
    1587
    744
    How much more rigid than a B-port??
    A bunch! I don't think I can quantify it; though, someone here will probably chime in with the answer.
    When I made the switch from manual to CNC (in this case a Milltronics, Partner 6) I was SHOCKED that I could hog away at Dia/Depth, Full slot, in steel.
    On your Haas (I have a VF-4, among other cnc's) it will cut SST great, with 5/8" -3/4" mills. It's not a Cat50, so no 2" indexable roughers... LOL
    It will spade drill a 1.0" at or close to the MFG's suggested feed, and tap a 1.0 x 8 without breaking a sweat.
    Where the machine will shine in SST, is in high speed milling. Light radial, heavy axial cuts work out well on the linear slide machines.
    Doug.
    OOPS! I misread the OP. I was thinking a VMC, not a TM3
  4. Likes Mtndew liked this post
    Feb 2016
    Washington
    125
    308
    68
    I ran a TM-1 for about 2 years and it was ok. I would definitely take it over an old bridgeport, but you will still have to be gentle. They don't have a lot of torque down low, so I would say smaller cutters are your friend.
    Are you making a couple prototypes or a bunch of different stainless parts in batches?
    Dec 2008
    New York
    9,222
    2389
    304 SS usually 1 hp will remove 0.2 to 0.4 cubic inches per minute
    just saying dont plan on removing 10 cubic inches per minute with a low hp machine as it will require up to 25 to 50 hp
  7. Likes Qwan liked this post
  8. #6
    Feb 2016
    New York
    28
    Default Thanks
    Quote Originally Posted by doug925 View Post
    Doug.
    Thanks Doug you did answer the same question I would have had for the VF3 how ridged it is for nice finishes on stainless. Do you run standard HSS cutters with the stainless?
  9. #7
    Feb 2016
    New York
    28
    Was the spindle casting and all ridged for nice finishes no chatter look or deflecting on stainless steels?
  10. #8
    Feb 2013
    Northern Mn
    449
    88
    511
    I don't have any TM3s, but I have had a couple TM2 and TM2p machines.
    The original TM machines are not particularly rigid. I think as much as anything, the rinky dink sheetmetal made such a racket, you would have thought it was about ready to implode. The new TM2P machine is a bit better.
    I never found the Bridgeports to be very rigid. The Haas is definitely more rigid than those. Obviously, it is less rigid than any of the other Haas machines (especially the VF3 chassis machines).
    Anything Haas will be less rigid than the substantially heavier Japanese machines.
    I would rather lick my dog's butt than use HSS for cutting stainless. It simply cannot withstand the heat and will break down very rapidly.
  11. Likes cameraman, doug925, pressbrake1, Qwan liked this post
  12. #9
    Jun 2002
    CANADA
    British Columbia
    2,292
    1572
    G00 Proto wrote:
    "I would rather lick my dog's butt than use HSS for cutting stainless."
    I would have to say there is ZERO ambiguity in that statement.
    I believe I know exactly where you stand on the issue of HSS cutters for milling stainless.
    Now I have to get the mental image back out of my mind...I'm having some difficulties!
    Cheers
    Marcus
  13. Likes cameraman, doug925 liked this post
  14. #10
    May 2011
    New Jersey
    1,191
    116
    589
    Quote Originally Posted by implmex View Post
    Cheers
    Marcus
    Implant Mechanix Design & Innovation > HOME
    Future thread: how to get better uncoated hss tool life in 17-4ss
    Future thread #2: how to get tin coated hss endmill to cut Cobalt chrome
  15. #11
    Jun 2006
    Alabama
    1,849
    1064
    720
    Ridged and manual Bridgeport???? HSS endmills in Stainless?????
    Thought this was a professional forum?
    Yes, the Toolroom Haas mill is about 5 times more ridgid. HSS is a waste of money.
  16. #12
    Nov 2013
    Utah
    3,192
    879
    1767
    The problem with comparing a POS toolroom Mill to a POS clapped out Bridgeport, is that compensating for all the slop in a CNC, takes a lot more thought and consideration than doing it on a BP.
    But to the original question; a Haas Toolroom Mill is about as rigid as a live worm about to get set on a hook.
    R
  17. Likes Mtndew liked this post
  18. #13
    May 2008
    SOUTH AFRICA
    1,476
    1058
    607
    Bridgeport and ridged should not be uttered in the same sentence EVER!!!! Yeah, they have their place no doubt but if you are talking SS and HSS I would rather have at it with my angle grinder! The fault, and also bonus, of a Bridgeport is that the table is so damn long in the X so you can fit parts on it that are awkward... but then look at the width of the slides compared to the table and you will know where I am coming from. It is versatile but it is also a POS if you actually want to remove serious material. I have had various Bridgeports and their chinese knock off's but now currently have a mitco (used to be locally made) that does not have that weak R8 spindle but rather a ISO 40 but it too is more for pitching holes, quick facing, tapping etc etc.
    Only Haas toolroom mill I have seen was, well to put it lightly, of no use to me in any way. But then again the same mill was making parts and money for the owner so no harm in that. I guess you need to weigh up what you want to do with it. If push came to shove I would rather buy an ancient Jap, non fully enclosed, machine than a Haas TM of any flavor. Just my opinion though.
  19. #14
    Feb 2016
    New York
    28
    Default Great Info, Thanks Much!
    Quote Originally Posted by G00 Proto View Post
    Thanks, Great Info!
  20. #15
    Feb 2016
    New York
    28
    Calm down RSTEWART, Forum is to talk about machining, Not to Judge!!
  21. #16
    Feb 2016
    New York
    28
    R
    That is the way they seem they would perform, Do you have a manufacture that you think makes a nice tool room mill and has it all going on? Love to hear it?
  22. #17
    Feb 2016
    New York
    28
    Quote Originally Posted by NAST555 View Post
    What manufacture do you think has a nice tool room mill with everything going on?
  23. #18
    Sep 2013
    Michigan
    272
    80
    142
    My current Lagun runs rings around any Bridgeport I have ever owned...
  24. #19
    Nov 2013
    Utah
    3,192
    879
    1767
    Sure, Okuma MB 560.
    R
  25. Likes TrollTuner liked this post
  26. #20
    Jan 2014
    Washington
    3,323
    642
    1716
    Do you mean some kind of no toolchanger, mostly open table, impractical, CNC? If so, then the best I've run is a Makino RMC55. No longer made. Its successor, is the KE55. Not sure if you can get that in the US though, I think it is Asia market only.
  27. Likes Kaszub liked this post
