Just as the subject says, how do I stop or at least minimize the number of times that my vise movable jaw jams?
You know what I mean, when you can't get it to open past a certain point so you end up cranking it forward and back a couple turns at a time as you hopefully make slow progress toward where you need to be.
I have a bunch of TE-CO (690 style/size) vises in an array on our one large mill and I cannot seem to consistently keep them from jamming up. So frustrating to need to open the vise from 2" to 8" (usually to mill one part only) and have to spend 5-15min just getting the stupid vise open....so a can run a 5min program on that one part.
I have tried removing the movable jaw when I clean but that doesn't seem to make a difference. I think usually it's a small chip gets jammed under the slide somewhere...could be in the screw but I don't know. Seems to crop up most often after I clean everything down with the washdown hose.
I don't want to have to take the vises right off the machine when this happens and fully disassemble them (worth it to do once if that would stop it from happening, but not every time it happens). I don't have those thin "chip shields" in these vises either. I thought about buying some but I figured it would make them more of a pain to clean....the chips are going to get in there since the vises are in an array.
Anyway, curious if anyone else is having this issue and how you have dealt with it.
Thanks!
Leviathan
Sent from my SM-G930W8 using Tapatalk
Thanks!
Leviathan
