How is this Surface Created?
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Dec 2019
    61
    24
    Default How is this Surface Created?
    I see this lined surface on a lot of putters, I have trouble believing those are scallops.
    Nov 2013
    Eastern Massachusetts, USA
    6,309
    5607
    5952
    The picture is not very clear but if you mean a pattern of longitudinal scratches that is usually done by a sanding process, often by a belt sander but sometimes by a belt on a rubber wheel of the Scott Murray type. The wheels have directional ribs that expand the diameter under centrifugal force to grip the inside of the sanding belt. They also have a cushion effect so they work very well for jobs like that. I've had one for years mounted on an old motor and it is wonderful for some tasks.
    PS: Most golf club heads are investment cast so they need little actual machining.
    Nov 2002
    3,345
    2019
    855
    Quote Originally Posted by sdinzy View Post
    When we made putters, the surface you show is done with side of an endmill.
    (the back of the putter was facing the spindle on op1)
    When the putter heads were machined complete, they were polished with a unitized abrasive wheel. (scotchbright wheel)
    Doug.
  4. Likes Matt_Maguire, D Nelson, DrHook, CarbideBob liked this post
    Jan 2014
    Washington
    5,411
    977
    3008
    Quote Originally Posted by Scottl View Post
    The picture is not very clear.......
    Plus it's about the size of a postage stamp. Too small to give any kind of useful answer.
  6. Likes 5 axis Fidia guy liked this post
  7. #5
    Aug 2013
    Chicago, IL
    1,098
    798
    422
    We get the same marks on parts coming out of our polishing department just like Scott said, but itís hard to argue with Doug if he used to make putters!
  8. #6
    guest Guest
    It's a golf club. Golfers will buy anything if they think it will take one stroke off their game.
    But it has to be different than everything else, so make the lines go a different direction. Then advertise the superiority of your design- the vertical lines make your putts go straighter...Don't forget to say "patent pending"...
  9. Likes Bobw, gmach10 liked this post
  10. #7
    Jan 2015
    Missouri
    1,287
    221
    804
    Doug is correct side milling
    Don
  11. #8
    Dec 2008
    N.E. Illinois
    454
    119
    237
    I'm a golfer. I thought fishermen were suckers for gimmicks till I found golf. Saw a putter with an advertised "Milled Face". If I left a finish like it go out the door I'd be right behind it!
  12. Likes Bobw, Mtndew, PegroProX440 liked this post
  13. #9
    Nov 2002
    3,345
    2019
    855
    LOL
    Try "German Stainless Steel" as a sales gimmick.
    Scotty Cameron (IIRC) first used it, and now everybody is using GSS vs SST. Haha!!!
    Now even Piretti (my old customer) is using the same marketing.
    Piretti Capri Tour Only German Stainless Putter | PGA TOUR Superstore
    Putters to men, are the same as lipstick to women.
    Men and women will buy small items like lipstick or a putter, even when the economy is tight, if they want a quick "Feel Good" purchase.
    Doug
  14. #10
    Nov 2002
    3,345
    2019
    855
    Quote Originally Posted by gmach10 View Post
    Ha!
    We used to intentionally "ping" bottom face of the putter, to give it the "handmade" look.
    You would be surprised how a little thing like making a run of serialized 20 pcs. (001 of 20, etc...) could raise the asking price to astronomical levels.
    That and a little "pining" on the underside, make the 20 pcs go from $150 to $750 just because they are exclusive, and only 20 were made.
    Ha! The Country Club crew eats this stuff up!
    Do that about 20 times, and rake in the $$$$$$$$
    (Just change the putter heads a tad bit each run)
    The coolest were the C110 copper putters. I still play with my personal one.
    Caveat: These putters were made almost 15 years ago. My customer was great all the way though the prototyping stages.
    Once they were big enough for the major (private label) putter machine shops, they took their business to production shops.
  15. Likes Kyle Smith, 3t3d liked this post
  16. #11
    Dec 2019
    61
    24
    Itís not the side of an end mill, I would have known that Itís a convex surface so it would not be possible to get uniform lines with the side of an end mill.
  17. #12
    Jun 2012
    Michigan
    5,440
    5086
    3406
    Quote Originally Posted by doug925 View Post
    LOL
    Doug
    $2,250??? Is this April Fool's?
  18. #13
    Dec 2019
    61
    24
    Sorry about the small picture guys, not sure why it uploaded so small. This should be better.
  19. #14
    Sep 2015
    Ohio
    1,430
    965
    1430
    Are you talking about lines from the front face to the back like little stripes? Kinda looks like it but might be a reflection from above?
    My guess would be that the bottom shape is not a uniform curve and those stripes come from either a flimsy "toy" mill that doesn't have the resolution to make very smooth arcs, or, a poor programmer who didn't filter the arcs fine enough (maybe intentionally) and that curve is actually a bunch of small line segments. Each line segment will leave a stripe. Makes the profile look faceted.
  20. #15
    Jun 2012
    Michigan
    5,440
    5086
    3406
    It’s not the side of an end mill, I would have known that It’s a convex surface so it would not be possible to get uniform lines with the side of an end mill.
    It could be a form tool, and they just side cut it. The machine lines tell us that it's cut with full length of flute and not stepped down or profiled.
  21. #16
    Aug 2013
    Chicago, IL
    1,098
    798
    422
    Yeah I think thatís an end mill. Iím not sure what you mean that it canít be because the surface is convex. The edge at the very bottom of the pic is hand polished/buffed.
  22. Likes doug925, TeachMePlease liked this post
  23. #17
    Oct 2014
    CANADA
    Ontario
    1,534
    1106
    1285
    Those look like scallops from a 'parallel' 3D contouring toolpath to me! Made with the end of a ballnose endmill most likely.
  24. Likes meowkat, richard newman liked this post
  25. #18
    Nov 2002
    3,345
    2019
    855
    Quote Originally Posted by Mtndew View Post
    Nope!
    Look at the GSS, misaligned and haphazard stamping (actually engraving) . That is by design. It is "handmade" and the stamping just keeps that image going.
    I am surprised that it is not serialized...for that price.
  26. Likes Mtndew liked this post
  27. #19
    Nov 2002
    3,345
    2019
    855
    It is a convex surface???? The sole is convex?
    I understand the 2 - 4į angle of the bottom of the putter to the face (loft), but I have not seen much in the way of a rounded bottom.
    Do you mean the convex shape is from heel to toe, or from face to back?
    If heel to toe, side of endmill. If face to back, then 3D of form tool. My guess anyway.
    Doug.
  28. #20
    Jan 2007
    Flushing/Flint, Michigan
    9,460
    518
    7865
    Looks convex in both planes to me now that the picture is see-able.
    The studder also looks very even but cusp or root shape hard to see.
    Side form straight flute endmill possible but a zillion passes with a small ball nose more likely to me.
    Sort of a poopy on purpose die finish when the stepover is large to the ball size followed by a deburr or a very nicely controlled prior op height and form.
    Make it good finish die surface and then add the grooves as if you where engraving on a 3D contour?
    I guess you only have to make such a program once but not fun to do and tool offsets had better be spot on to nail the flat widths between each groove which seem very good here.
    Lengthwise surface profile on a contracer or profilometer chart trace would be interesting but maybe hard or expensive to come by.
    Be aware that looks like it to your eye is sometimes (or often) not It.
    I would think the flats here critical along with the edge/corner that transitions to the grooves.
    Not an easy part to copy and for sure some trade secrets in the process.
    I do so hope you are not trying to rip off a design and are making something new of your own being a bit better or different.
    Bob
