Im not a cnc professional or even a learning cnc operator,Im a student, currently studing my fourth year in mechanical engineering, Im required to study cnc as part of my syllabus. Im a newbe to cnc.
Can somebody please explain G41 syntax used for tool offset.
Let's say during a side milling operation, a 40mm diameter tool is used, so an offset is specified using a syntax as follows:
G41 D4
From what I understand from the above syntax is that, D must be followed by a number obtained by dividing the tool diameter by 10. Am I right? I've seen another example where a 25mm diameter tool was used and the D there was followed by 2 and not 2.5 (25 divided by 10). How come?
Can you please explain how the number that must be followed by "D" must be obtained.
Thank you.
G41 D4
Thank you.
