I picked up a bmc 20 machining center for really cheap. Its in perfect condition they used it for machining plastic. The machine has been sitting for at least 5 years in cold storage. I got it powered up and after fixing several sticky limit switches i had it functioning. The spindle gave me a couple errors the spindle drive had a UU on the display. If i cleared the error it would work again. I was working on the x overtravel switch and the servos shut off. I cant get them to re enable. There are no errors on the screen. I have checked voltages inside the box in the rear and everything seems to have output. Checked all the fuses. If i manually energize the servo contactor
The drives power up don't see any errors on the drives themselves. Does anyone have any other ideas?
I suspect something to do with the crp control relay board?
Thank You
Jason
Thank You
Jason
