Yep, still using one of these old dinosaurs even now. Or rather using it again. Had a couple I was using to pay the bills years ago and kept them when I went to work for the university. Well, the shops on campus are all locked down so I'm working from my home shop and that means dusting off the old Hurcos.
The good news is the machine works, mostly (I have to warm it up for a while before zeroing the table or it hangs while looking for Y after going to the limit switch) but the dimensions of the finished parts suggests it's past due to adjust the backlash and leadscrew compensation strapping.
I have the requisite 13.1" bar made up, I have the chart from the service manual giving the details of what straps give what compensation.
(also available on Buddy's site: http://hurcousa.com/strapping.php, thanks Buddy!)
What I don't have is a handle on the procedure. Does the machine use the strapping value present at any given moment or do I have to re-zero the table, reload the master, or reboot the whole machine before the changes take effect?
There are six blocks and the strapping sheet says the top row is leadscrew, bottom row is backlash. but not if they are in X,Y,Z, order or not?
While on the topic of antiques, I have a couple other questions:
Where is the control for the auto-lube, I see a electromechanical timer in the electronics chassis but I think that just runs the lube in the spindle housing?
Turning the manual feedrate override pots also affects the spindle speed. I'm pretty sure this isn't supposed to happen. Suggestions?
My Y axis has some palsy, particularly when cold. I tried tuning the servo but during the "Adjust (GAN) until the motor starts to oscillate, turn (GAN) CCW until oscillation stops,
then turn an additional 5 turns CCW." stage, the Y axis never really oscillated. How worried should I be?
thanks folks,
thanks folks,
