Hurco sm1cnc display help
Results 1 to 12 of 12
    Jan 2007
    Detroit Michigan
    41
    Default Hurco sm1cnc display help
    I went to use it today and no display. Well a little glow near the bottom of the crt. Everything else worked as I jogged the machine around and used it like a manual mill to get the job done. Where should I start it has a z axis monitor? 1984 make machine.
    Don
    Jul 2010
    Wisconsin
    418
    299
    I made a bracket to mount a regular monitor to our hurco ,unplug the touch screen and plug into the monitor.You have to use the keyboard function keys instead of the soft keys on the side of the touchscreen.Cheap fix.
    Jan 2007
    Detroit Michigan
    41
    Thanks. But this is an older machine with bx controls I doubt the output is compatible with a standard monitor.
    Don
    Jan 2008
    Bucks, England
    399
    18
    64
    The output is just composite video (just like the signals that run in the yellow plug on older VCRs).
    Jan 2007
    Detroit Michigan
    41
    Thanks. Maybe a should pick up cheap monitor.
    Don
    Jan 2008
    Bucks, England
    399
    18
    64
    If I remember correctly, the wiring was in this order in the plug to the monitor:
    Video
    0V
    15V
    0V
    Jan 2007
    Detroit Michigan
    41
    Thanks. I picked up a 9” monitor from eBay for $37 and it works. All I need to do is make a bracket and it will mount in where the old crt was. Sure beats the $750 estimate I got for a repair.
    Don
    Jan 2008
    Bucks, England
    399
    18
    64
    Excellent!!
    Sep 2005
    Oakland, CA
    2,395
    231
    627
    We have used Dotronix for our Hurco monitor repair for a very long time. Prices have always been pretty reasonable. Pretty sure your old monitor is a Ball, as most of the B and BX machines used the same monitor. You might just contact them with yours. It would be interesting to find out if they are still as reasonable as they were in the past.
    Home - Dotronix Technology, Inc.
    Jan 2007
    Detroit Michigan
    41
    Up and running total under $50.
  11. Likes Roooster, Dan from Oakland liked this post
  12. #11
    Sep 2005
    Oakland, CA
    2,395
    231
    627
    Would you mind posting a link to the one you purchased off ebay?
  13. #12
    Jan 2007
    Detroit Michigan
    41
    Quote Originally Posted by Dan from Oakland View Post
    This and a 12v dc converter that was about $5 since the old crt was 15v
    Ultra Thin 9" Inch TFT LCD Color 2 Video Input Car Rear View Monitor HD 800X480 | eBay
