ShootingSight
- Jan 15, 2015
- Cincinnati
I'm posting this, not because I have a problem I need help with, but because I HAD a problem I needed help with, and could not find it, and eventually I solved the problem. So I'm hoping someone googles this in the future, and finds it useful.
I bought a used Hurco VM-1, 2007, from 520machinery, an on-line broker. I sent in the Hurco rep before buying it, and it checked out OK. I paid, trucked it to Cincinnati on an air-ride, and it arrived DOA. It would not boot - black screen. I called the local Hurco rep, they came in, pulled the boards from the controller, and lo! it booted. Happy, everyone went home. Next day, after I power cycled it, it would not boot again. I pulled the boards and re-seated them, it booted ... but 30 minutes later the software froze. I had to power cycle, but then it would not boot.
Hurco rep on the phone said it sounded like it needed a new CPU board ... at $2700! Screw that. I spent a week trouble shooting to no avail.
520Machinery didn't offer to help - their contract said 'no warranty'. I can't argue legally, because it said it right there on the document I signed ... however when someone makes a profit off me and I get a DOA machine, I would imagine you should suck up some of that profit in hopes of retaining a happy customer. Not so much. So I will not do business with 520Machinery again.
Kudos to Hurco Corporate. They got me connected to an engineer who emailed me to call him to talk through troubleshooting. I never did, because I fixed it, but at least they were trying.
At the end of the day, I did google searches, so did a buddy of mine, and we ended up with one obscure post from England (I think), where this guy claimed he whacked his motherboard on a table, and it worked. Whacking on a table seems a little extreme, but it got me thinking. THe only thing on a motherboard that is succeptible to a whack are the pin contacts between the CPU chip and the board in the ZIF socket. So rather than pulling the board, I just grabbed the CPU fins and wriggled ... it booted. So I pulled the board, removed the chip, squirted it with contact cleaner, replaced it .... it booted 2-3 times, then balck screen again.
At this point, a Hurco board is almost $3,000, but a board with the same serial number (or very similar) on ebay is $200. It was a Nextel of some sort - no longer made, however I wanted to call Nextel CS and find out what the exact difference in model numbers was, because I'm pretty sure I could have substituted. Long story short, I also saw on ebay that the actual CPU chip was a Socket 478 Pentium 4, which was selling for $5. Being of the mindset that when I'm footing the bill, I'll try solutions prioritized based on cost, rather than probability of success, I bought a chip, swapped it out, and it has been running fine ever since.
In looking at it, the controller is a back-board with cards stuck in horizontally. I'm sure it was designed as a horizontal board, with cards stuck in vertically, but in the Hurco configuration, the weight of the card is cantilevered. I'm sure that as it flexed in trucking, one or two of the CPU pins wriggled loose. I hate 'marginal' electrical problems, but in this case it contacted occasionally, and when I wriggeld the board, and it contacted occasionally again.
Bottom line, if you are having black screen boot problems, look at the seating of the CPU chip on the motherboard.
Regards,
Art
Regards,
Art
