sheys
- Jul 13, 2006
- brooklyn, ny
I'm doing some design work for a kinetic sculpture and I'm considering using a simple, low pressure hydraulic system for actuation. Ideally I'd like to use a pair of single acting cylinders attached to each other with just a 10' hose and a fitting to bleed the system, no reservoir. Pressure would be LOW <200psi. One side would be a commercial cylinder (like this: 1.625X9 SA HYD CYL 5800 PSI), the other i'd make out of honed ID AL tubing with a custom piston and seals. The commercial cylinder would be driven by a motorized screw and the custom cylinder would be slaved. Return is by gravity as the screw is backed off. This is a SLOW motion, a few minutes to retract a few inches.
Simple, right? Well, I'd have a couple dozen of these master cylinder/slave cylinder/hose assemblies in parallel driven by the same motor to lift a number of objects evenly. Each pair acts as its own closed system, no oil mixes anywhere. I need all of the cylinders to be exactly in sync over a long period of time. I'm not aware of an easier way of keeping the position of 24 cylinders coordinated without a closed loop control system.
My concern is potential leakage past the piston seals, I don't know how much to expect. This piece would be running for many months so even a very tiny leak rate would eventually be a big problem. Any oil that escapes from the closed system will end up on the floor and cause the slave cylinder to lose position. A drop or 2 of loss a month is probably OK but more than that would be a big concern.
So, is this a bad design? How much oil will I lose past a pair of 1-2" ID piston seals at 200PSI after a month? I've been searching around for references to similar systems (master/slave with NO reservoir or valving) and haven't found much. I plan on setting up a test ASAP but wanted to get some opinions here first.
Thanks for any input!
