Hyundai HIT 15-s start up
Likes Likes:  0
Results 1 to 13 of 13
    May 2021
    7
    Default Hyundai HIT 15-s start up
    hello, I bought two Hyundai hit15s that were under power. I am an electrician by trade and I cannot find anything other than 3 phase 440 on the tag of the machine. so hooked up 3ph 440 to the machine disconnect and turned it on. About ten seconds into loading up we heard a pop and then a second. it blew the soldered fuse on the board on what I believe is a power supply on the bottom of the right hang door on the control cabinet. the second machine is a parts machine I have a spare power supply, but I don't want to swap it out without fixing the problem. any help would be appreciated thanks
    Mar 2008
    vacaville ca
    575
    90
    153
    if its what i think its a siemens control runs on 400v. was it connected through a transformer?
    May 2021
    7
    Quote Originally Posted by pcasanova View Post
    hit15s have a transformer built in so I applied 440 volts to a step-up transformer which stepped it up to probably well over 1000 volts to the machine. I ended up stealing from the one machine that was not running to fix the the one that was. I blew fuses in one board and fried 3 others, I can't believe I didn't catch it.
    a lot of damage was done in several seconds. I was able to put in the parameters today and was trying to get the spindle to turn using MDA. I find the setting to change the max spindle speed as it is set at 100rpm. I cannot get my cursor to select the spindle speed.
    Jul 2006
    Wisconsin
    1,458
    293
    1041
    Use the up/left diagonal key to select the max rpm section in the axis/ spin page
    May 2021
    7
    Quote Originally Posted by JP Machining View Post
    thanks ended up figure everything out except now I'm getting an error code randomly 9100 servos not ready and 9000 emergency stop. I ran parts on and off most of the day now it won't let me run more than facing the part before it shuts down.
    Mar 2008
    vacaville ca
    575
    90
    153
    9000+ are going to be machine builder codes. not sure how how yours are wired, but see if you have a wire daisy chained between 'as' inputs/outputs on the drives and see if you get a 24v signal all the way through. if one fails you will loose the signal and should be able to pinpoint the failing drive. the machine I had the 840c control was pretty good, but the 611a drives were just bad.
    May 2021
    7
    thanks are you referring to the main drives or the plc cards.
    Mar 2008
    vacaville ca
    575
    90
    153
    axis drives,
    May 2021
    7
    axis drives,
    i just looked and its a 611
    May 2021
    7
    i can run a program 10 times and it wont throw the 9100 code but as soon as i tun the rapid override from 0 to 10 it faults
  11. #11
    Mar 2008
    vacaville ca
    575
    90
    153
    try running x only then z only and see if it faults on one or the other or both
  12. #12
    May 2021
    7
    we believe it is faulting on x it also throws 1680 ord X servo enable traversing axis code now
  13. #13
    Mar 2008
    vacaville ca
    575
    90
    153
    swap x z drives and see if the error follows, if the error follows most likely. more thinking its a failed power base pretty common.
