randomy220
- Dec 7, 2018
So recently I started training for a cnc programer and I'm using fusion360 but the x axis will not go to where I tell it to. For example if fusion tells it to go to x5 it will always do it but when I measure the diameter it's 2mm or more bigger.BUT here's the interesting part. If i enter g1 x5 into the MDI it makes it how its supposed to. Also on the display it says its on x5(even tho its not) and the backplot looks right for more complicated parts.Also also we recently moved the lathe from one corner of the shop to the other so that may affect it somehow?
I'm still new to the cnc world so sorry if this is something simple but I will appreciate any suggestions and tips you have.
