The machine spindle is stuck in neutral. It has a Fanuc 6b control but you can't shift it out of neutral by way of the control. There are three solenoids that control low speed/high speed and tool unclamp. I can manually move the solenoid into low speed but you can't unclamp any tools or move it into high speed. It appears to me there is no power going to those solenoids. There is an SSR encoder on the back of the machine but I'm at a loss to figure where the power is supposed to come from or where the problem might be. The machine has sat with no use for about a month but not sure that should have anything to do with it. Any ideas?
