I need help with Fadal 4020 tool setting
Likes Likes:  0
Results 1 to 6 of 6
    Dec 2005
    Iowa
    206
    19
    Default I need help with Fadal 4020 tool setting
    I can't seem to figure out what I'm doing wrong I set the tool using the tool setting program. if I set the tool height it adds the set block length in such as -19.000 withe a 3" block for a -22.000 setting. When I use the fixture setting cycle it reads a negative number for Z height. WAtching a video on Youtube by AT-Man Unlimited the z number changes to a positive from the tool height setting to the fixture offset number.
    Aug 2005
    Manchester, MD
    257
    30
    When you call your tool height offset H it will change. I keep my Z fixture offset set to 0. So with no tool height offset called, 0 will be the Z tool change position. With H called, 0 will be the tool 0 that you set.
    Jul 2019
    Idaho
    10
    6
    5
    Same here. I leave the "Z" parameter in the fixture offsets set at zero, and control the Z with the tool height offset.
    I zero every tool to the table itself. Then, depending on what fixture I'm using, I use the "mass modify" operation in the tool offsets menu, for the specific fixture I'm using.
    So for example, say I want to run a part that's held in the stepped jaws of my vise. The step is 5.900 above the table (I know this because that's where I machined the jaws).
    So in that case, from "Enter Next Command" I'll hit space, 6, 3. It then prompts me for the starting tool number. I enter 1. It then prompts me for the ending tool number. I enter 22. It then prompts me for the offset. I enter 5.9. Presto, all my tools are now zeroed to the step of the vise jaws. I only have a 21 tool changer, but position 22 keeps track of where everything is set. It'll have 5.9000 in it.
    Later I want to run something that sits on a different fixture that's 3.0763 high. I hit space, 6, 3, and look at the offset for tool 22. I see it's 5.900. I then do a mass modify on tools 1 through 22 again, entering -5.900 as the tool height offset. This brings everything back to the table. Then I mass modify 1-22 again, entering 3.0763 as the height. Presto, all tools are zeroed to the fixture, and 3.0763 is recorded for position 22.
    This is the way I was taught to do it when I got my first Fadal in 2003. Early on, I noticed that the fixture offsets table also has a Z height offset parameter. I experimented with using it instead. It didn't work, and I couldn't make sense of how it was behaving, so I just went back to the way I was taught. Been doing it this way for 16 years now. Works fine.
    Sep 2010
    Oklahoma City, OK
    4,030
    706
    1725
    Quote Originally Posted by ZfMax View Post
    Right there with ya buddy. I'll try your method next time.
    Jan 2016
    New Jersey
    191
    62
    80
    IMO, use Aaron Gough's macros:
    A Fadal toolsetting system that doesn't suck!
    Mass modify is probably a similar speed, but the macros do reduce the chance of fat fingering something. They also fix the issue ZfMax was having with fixture Z offsets. Very handy tools.
    Dec 2005
    Iowa
    206
    19
    Thanks guys for the help. I understand now how it changes as a H height. I like the mass modify idea.
