Machine Type: FP50CC
Serial Number: 2813-0234
The problem is as follow:
When the system starts, the sequence of starting runs normally and then it finally gives the indicated status in attachments.
Pushing green control ON button in the operator panel has no effect i.e. (drives not start), the machine then gives no error messages and no alarms as indicated in attachment "monitor1.jpg". But the abnormal behavior is that after the sequence of starting is finished:
The (READY) led in the NPC card is ON whereas the (RUN) led in this card is OFF as indicated in attachment "Dialog11.jpg"
The (CNC) led in the NSV card is OFF as indicated in attachment "Dialog11.jpg"
Please give help to fix this problem
Aiman Ebraheem
Aiman Ebraheem
