So this part is currently being done in a few setups. Basically gets milled down on both ends, then put into the lathe to put in the center taper, then flipped over for another one of the side tapers then set up again for the taper on the opposite side. After that, put back into the mill for the broaching.
Basically looking for any ideas to do these complete in one or two setups on the HMC. These parts come with the periphery flame cut, and building fixturing and tooling up is all thought of if we can get a better time on these things.
The best and (in my opinion) only good idea I've heard so far is step drilling and then going through with a tapered reamer. Admittedly I don't always have the best mind for these things so I'm curious to see what some of the brighter minds on this forum think.
Thanks all.
Edit: realized there's no vertical dimensions on that attachment. Center bore is 4.88" and bores on either side are 4.00"
