"Improper G-code" alarm when using G71 on Fanuc 21T
Results 1 to 9 of 9
    Feb 2014
    Ohio
    432
    33
    35
    Default "Improper G-code" alarm when using G71 on Fanuc 21T
    I used to run this exact program on a lathe with 0T but on my Hardinge Cobra with 21T control I get a #10 Improper G-Code alarm when using canned cycles. I've looked through the parameter manual and have even talked to a Fanuc tech but haven't had luck finding what parameters to change to enable the G70-G73 canned cycles. Can anyone help? Fanuc says they'll dig into it and try to find it, and I left a message for Hardinge tech support.
    Jan 2014
    Washington
    4,066
    761
    2146
    What's your parameter 9921 bit 7 look like?
    Feb 2014
    Ohio
    432
    33
    35
    It's set to 0. The entire line is 01110000; this is what the Hardinge build sheet had on it and it matches the machine.
    Johnny Larue Guest
    alarm 10 in an improper G-code....my guess is the program is incorrect....is it long?
    heres alarm list for controls
    Fanuc 16,18,21 Control Alarms | CNC Alarms.com
    and heres the 21T manual
    Fanuc 21 Manuals User Guides - CNC Manual
    Jan 2014
    Washington
    4,066
    761
    2146
    Quote Originally Posted by Ukraine Train View Post
    That shows that the machine was not purchased with the G70 series canned cycles. If you can get bit 7 set to 1 you'll be in business.
  6. Likes yardbird, Ukraine Train liked this post
    Feb 2014
    Ohio
    432
    33
    35
    Thanks! That worked. Funny, because the Fanuc tech asked me about 9921 also and then dismissed it.
    Jan 2014
    Washington
    4,066
    761
    2146
    I'm surprised that the Fanuc guy would even ask about 9921 and not just say you were missing an option. Alarm 10 is pretty clear about in that you have entered a G code that is not included in the control configuration. I don't ever recall seeing alarm 10 associated with anything other than not having an option enabled.
    Why Hardinge did not include the G70 series cycles as standard is weird too. I guess they were trying to make an extra buck selling control options that most other builders include as standard.
  9. #8
    Apr 2019
    INDIA
    Hi actually i'm also stuck by this problem with same hardinge machine yet i read your message then i tryed to change this parameter while in mdi and write enable on but it dosen't change from 0 to 1
  10. #9
    Mar 2003
    Upstate New York USA
    281
    43
    The G 70 canned cycles was an option on that machine model in order to keep the selling price as low as possible back at the day
    Tom
