claya
Cast Iron
- Aug 6, 2006
- california
Suggested start point on radial and Axial DOC profile milling using a high end 1/2" endmill (IMCO 924) for Inco 718 annealed?
So that works out to 209sfm? (if I am doing the math right). With a 0.02radial doc, is that for finishing or roughing... OR both?1600RPM, 40IPM, .02" stepover, DOC all of it
That's 458sfm. What kind of tool holder?I would HSM using an Imco IPC7 POW R PATH (7 fluter) If you have a rigid setup somewhere around 3500 at 55 IPM tool life would be 45-to 1hour.
Make that 1400 rpm at 43 IPM .035 used titanium numbers.
What radial and axial doc?I would HSM using an Imco IPC7 POW R PATH (7 fluter) If you have a rigid setup somewhere around 3500 at 55 IPM tool life would be 45-to 1hour.
Really high, based on using the generic 60sfm speeds&feeds. And a long enough lead time to accommodate the above.Just curious but what did you bid this job at?
I mean you must have had an idea of how to cut this stuff when you quoted the job.
Sent from my SM-G975U using Tapatalk
Given that I only have TG-100 collet holders on a very rigid machine (and standard holders on a less rigid machine), what sfm profile milling and slotting would you suggest? I have to deliver this job in 2 weeks, using what I have.I wouldn't trust a collet holder for this.
Make sure the tool is running true, I shoot for .0005 tir ...using maritool holders
We are running IMCO S&F. M924 4F. How much sfm way over are you running?Collet holder go conservative check for pullout occasionally...slotting yeah I would go with the 4 flute
See IMCO online catalog for speeds and feeds on this...profiling I find we run way over suggested but slotting just bites.
The material showed up cut significantly oversize. Plus several other snafus from quote to PO. Every possible thing that can go wrong on this job already has.
So any tips that anyone has for actually running carbide MILLING tools in INCO 718 at 160+sfm (or 450sfm??) is the only advice that helps at this point.
Notice
