info on turning tols
Results 1 to 17 of 17
    Oct 2006
    Ireland
    453
    30
    74
    Default info on turning tols
    Hi All,
    I have a part 125mm long (5")and it requires turning to a shoulder
    of 5mm(3/16 ish).Dia is 19mm (3/4" ish)the tolerance is 0.01 (0.0004)total .zero deviation in 304 st st.
    We would buy a machine to make the parts. Every machine maker gives us "a no problem"
    But I have listened to crap before.
    Please can I have your views.
    Thanks GTW
    Jun 2012
    Michigan
    10,218
    3465
    3647
    The very best machine in the world can have trouble making that part.
    Operator skill and quality of holding device are keys to success,. and yes the machine.
    Good that at 3/4 x 5 it is a stout part and .0004 is not that chose if +-.
    .0004 TiR (total) is considered very close and on some machines may need be done between centers, or have very good holding device.
    Parted off would make it easier. Out of a collet or chuck the holder would have to run <.0002 if .0004 TIR.
    For close grinding I have clocked a spindle to find perhaps .0001 error and a put a paint spot at the high place..Then with finding the collet .0002(very good for most collets) I match high and low to get closer to zero..
    Dec 2014
    Washington
    211
    355
    86
    If you can use a center or false center than this part is easy. If not you might check out roller box style tools, though not sure if you can get to a square shoulder with them.
    Aug 2013
    Chicago, IL
    913
    629
    348
    I don't know boo about 304 but a, "long, skinny part with tight OD tolerance" is where sliding headstock (i.e. "Swiss") machines shine. Think Citizen, Tsugami, Star (in that order.). The cutting generally takes place 1mm out in "Z" from the guide bushing support so it is very rigid. It's a heavy cut but a positive insert would help keep the load and tool deflection under control. I regularly turn down 4340 from .875 to .470 and hold +/- .001" with non-ground stock using a DNMG. Good luck!
  5. Likes AARONT liked this post
    Feb 2013
    Madison, WI
    1,045
    1143
    677
    Quote Originally Posted by Nerdlinger View Post
    This. And if it's not an issue for them, ask them to provide you with sample parts and a quote to have the machine dropped on your floor turn key.
    Oct 2006
    Ireland
    453
    30
    74
    Default Turning tol's
    Quote Originally Posted by AARONT View Post
    Sliders are great but the tol. is .0004 total. and the oval problems using a guide bush
    can put you out of that let alone 120mm + lengths. Roller boxing again is a great thing but
    the tol. is to close over the distance (I set them for years).
    I agree we would not buy a machine without a trial
    run.
    Feb 2014
    Sunny South West Florida, USA
    2,955
    10854
    3337
    Centerless form grinding?
  9. Likes Bobw, mmurray70 liked this post
  10. #8
    Oct 2006
    Ireland
    453
    30
    74
    Hi TeachMePlease,
    This is an option we would consider. Also a hard turning machine.
    We would also do this internally and buy to suit our needs.
    I am leaning to this direction for production / quality consistancy
  11. #9
    Aug 2013
    Chicago, IL
    913
    629
    348
    Quote Originally Posted by Gerrythewelshman View Post
    I do not work in the world if +\- .0002” but I know Star and Tsugami (maybe Citizen, too?) offer optional pneumatic guide bushings that always maintain even pressure around the bar. This helps with varying bar diameters and would definitely help with ovality but I do NOT know if +\- .0002” is reasonable. It wouldn’t surprise me, though!
  12. #10
    Jan 2020
    Colorado
    Swiss will be the way to go. Look for something with a second gang tool post or turret so you can pinch-turn. You'll basically have the rougher & finisher engaged in the cut at the same time.
  13. Likes mhajicek liked this post
  14. #11
    Aug 2002
    West Unity, Ohio
    25,561
    5811
    8178
    Well, you didn't state what the bar stock size is, so hard to tell how well the Swiss is suited, but I doo agree that if you chose the Swiss, you would want to git the pneumatic guide bushing. (if trying to produce finished part)
    While it can be done within reason on either fixed or sliding headstock, if I was planning on making umpteen of them every day - as you seem to be preparing for, I would lean towards roughing out on a lathe and finish plunge grind on centerless to finish. You will hold your tol way better on the grinder and it's a quick opp. Quicker than that final cut on the lathe.
    If you blank on a Swiss you don't have the center in the end, nor the time to produce it.
    The grinder will take the sub collet marks off too.
    edit1:
    Also note that you will get 2 less parts per 12' bar on the Swiss (if running a guide bushing) and on big diameter SS - that can add up quickly.
    Likely about the same/bar if running a short loader tho.
    edit2:
    If you went Swiss, you would want to make sure that it is a machine that can pinch turn. (Again - depending on bar size)
    That means twin turret usually, so ends up not being a very cheap machine.
    edit3:
    Also note that 304 has a bad reputation for consistancy.
    The grinder will bring consistancy to the table.
    Not sure what "zero deviation" means?
    Think Snow Eh!
    Ox
  15. #12
    Aug 2013
    Chicago, IL
    913
    629
    348
    Some Swiss machines are available with tooling next to the sub spindle, intended to be used for drilling deep holes in the part on the main spindle side, but I bet you could put a boring bar in there and use it to pinch turn. It’s still a $200,000 machine if you need a magazine barfeed.
  16. #13
    Feb 2014
    2,955
    10854
    3337
    For that, you could use one of these: DS-ACH Toolholders - Unique Tooling - NTK Cutting Tools (The Americas)
    The only downside is the 5+" overhang you'd need to clear the finished part.
    I'm a big Swiss guy, it's more or less all I do, all day, every day... and given the time and resources, I'm sure I could make this work, reliably...
    But if looking for a turnkey solution, with minimal fuss and adjustment, with a dedicated machine... I think centerless grinding is the way to go for these parts/tolerances.
  17. #14
    May 2017
    Minnesota
    1,131
    1415
    776
    How many do you need? Might be easier to job it out to someone that already knows how to do it.
  18. #15
    Jan 2019
    Arizona
    757
    66
    251
    Maybe I am reading this wrong but asumming the shoulder is on the o.d.
    if its an I.d. shoulder Ie step with a 3/16 bore 5" long + or -.0002
    Remember the tools dont move on a swiss in the Z direction . The stock does.
    I dont think a swiss will work for O.D. shoulder reason being is it goes from a 3/16 dia to shoulder of 3/4 dia. somewhere in 5" or its longer
    unless you can take that whole cut in one shot, its going to fall out of the bushing after your 1st cut going for the other cuts.
    if you can find a tool to make the entire cut from 3/4" to 3/16 dia, it would be possible if and only if had a sub sindle that could grab the front of the part 3/16 dia and move back while feeding ( TeachMePlease will understand) Typically a bushing is about .5-1" long of actual dia.
    The stock would have to be ground to the biggest size in which case is 3/4"
    and depending what fillet if required between the shoulder face and the centerless might not be an option, o.d. grinding might be the only option
    If the guy had a mark up print it would be easier to tell. I dotn think he understands machining very well, his explanation is very vague.
  19. #16
    Jan 2003
    Canada
    11,296
    5492
    3422
    I think we ain't all picturing the same part. Is it 19mm material being turned to 5mm. Or Bigger material being turned down to 19mm and the shoulder is 5mm thick?
    If its turned to a 19mm dia, that's easy enough.
  20. Likes Ox liked this post
  21. #17
    Jan 2019
    Arizona
    757
    66
    251
    Quote Originally Posted by SND View Post
    yeah thats what I mean I cant figure out what he wants exactly because he says shoulder.
    Hi All,
    of 5mm
    if he is just turning 19mm to 3/16 rough it down and centerless grind it its a simple job then. a screw machine would be out of the question those do to length and bushing like explained above) any lathe would work fine otherwise.
    Thanks GTW
