Dupa3872
Stainless
- May 1, 2007
- Boston Hyde park Ma.
Guys,
I run these parts and parts similar quite often in our HAAS SL-20 lathe. I am using a Sandvik 1.00 coolant thru drill (no High pressure)
I am going 2.10 deep to a flat bottom. The drill is fairly new and inserts are changed as needed.
I want to go as fast as possible but don't want trouble it's 200 piece run. Over the years we get good runs and bad runs using the same program, the drill loads up or will push the part back in the collet (I'm using a W/S S-20 collet Pad nose) and we slow it down it's a pain in the ass at times and I want better consistent cycle time and good parts.
This hole finishes at 1.125 X 2.1 deep. I am drilling with the insert drill then using it to bring my bore within .010-.015 and my last move is in X to center once I reach bottom, Like facing it, leaving .005-.01 on the bottom for the finish tool.
I just want to see speed and feed opinions. And if someone has a better tool in mind say so, remember it's a flat bottom hole.
What about taking out the middle with a drill ? Ive always heard you should not Pre-drill before an insert drill.
Thanks Guys !
Make Chips Boys !
Ron
Thanks Guys !
Make Chips Boys !
Ron
