I got the head in there, centered and dialed in the ruby within .0001 TIR.
Ran the calibration XY and it seems good there.
How the hell do I set the Z?
What is z zero on the machine? Top of table?
I see there is a z calibrate program, but I am to set it .500" from zero point. Which I don't know where that is.
Little help?
Jon
It sounds like you’re running the Blum/Yamazen probing cycles if you have a Z Calibrate program. If you’re running Renishaw, touching off the probe is all that is needed.
Make sure you run the XY Calibration cycle a few times. First run usually measures small, second one usually a few tenths big and they get closer after that. May take four or five cycles to get it to match your ring gage size. Check the Macros page and look under the 100’s, you’ll see them populate. Going off memory right now, I think it’s #106, you’ll see it if it’s not, the ring size will populate. Run it until it matches your ring gage diameter.
Make sure you touch off your probe on your tool setter before calibration.
Z0 is the face of the table. So Machine Absolute Z would be the spindle gage line touching the table.
Program 702 (usually) will be the Z Calibrate program. There is a work offset at the top, usually G59, but check before starting. Whatever gage block stack or 1-2-3 stack amount to, including anything they’re on top of like a sub plate, etc, as Frank mentioned, needs to be added together. This total stack height needs to be populated in the work offset that’s in your Z Calibration programs Z value. So if G59 is in there, stick the stack up value in G59 Z.
The numbers within all of the probing cycles are relative moves, so you’ll see a Z-.25 or Z-.5, whatever it is, position the tip of the probe within that value to the top of the gage block stack and cycle start it. I’ll usually run XY and Z calibrations slow once to make sure everything functions, but make sure you run them at 100% feedrate after that to get accurate readings/calibration.
After the Z calibration cycle runs, run a Single Touch Z (usually program 707) to another work offset on the same gage block stack then compare the two Z values. It’s usually dead on after the first 100% feedrate cycle.
Once the calibration cycle is complete you can clear out the work offset Z values used for calibration and the one you set with Single Touch Z.
