Premier DT
- Oct 28, 2020
So, I am new to CNC machining and have recently been getting my head around some basic OD turning, grooving, threading and even some Y-axis live tool hex flats. However, next I want to tackle some half circle radii. Both internal and external. Our machine has a sub-spindle if necessary but I'd much rather do everything on the main spindle if possible, especially boring.
The part in question has a 1mm radius, half circle, on the ID. My idea is to rough it flat as big as I can and then go in with a grooving tool of some kind to clear out the material between the 2 radii, however would I be able to cut a small radius with a grooving tool? Same question would go for radii on the OD as well. I'd rather not use a left hand tool if at all possible. Anyway I'm new to this, especially boring (broken 1 tool already) so any help is appreciated!
