involute serration help
Likes Likes:  0
Results 1 to 3 of 3
    Jun 2013
    california
    6
    Default involute serration help
    hello , i need some help machining involute serrations.
    the print says
    american standard involute serrations
    per 02-1698,
    external
    teeth on edge of flange
    48/96 diametral pitch
    56 teeth
    1.1875 major diam .
    I have the machinist hand book , to reference but im not sure .
    does anyone know the pitch diameter ? or how to figure it out?
    I will be using a 45 degree key cutter to machine this on a 4th axis rotary.
    Sep 2005
    Oakland, CA
    2,431
    256
    649
    56/48=1.1666
    Jun 2013
    california
    6
    Default thanks
    Quote Originally Posted by Dan from Oakland View Post
    56/48=1.1666
    thanks !
    do you know what pin diameter to use to measure?
