So I have a 2004 haas vf2. I was having an issue with coolant leaking badly from the back where the way lube tank and oil separator is. Pulled the panel with the way lube and air and blew out the reservoir where the coolant is supposed to go into the oil separator and back to the coolant tank. It was full of chips. Now the machine wants to home out the y axis backwards. It goes all the way to the back and alarms out. Loads up. Tried wiping everything I can reach out from the back but it still does it. I didn't disconnect anything. I think maybe there's chips on the limit switch? I'm not sure. But I don't know where the limit switch is to check.
So does anyone know where the y axis limit switch is or possibly another solution?
Thanks.
Thanks.
