Hello everyone!
I have a problem with my cnc lathe haas st10-y with live tooling. I work programs with solidCAM. So...when machine milling with axial live tool with C-axis (operation does not metter - iMachining, pocket operation) on external diameter 40mm is everything ok, but problem is, when mill on diameter on 10mm or closer to the center of workpiece then machine stop working and i get an alarm message ˝09971 EXCESSIVE AXIS SPEED OR ACCELERATION˝. I tried everything to fix the bug, but it doesn't work. I must fix manually the program and manually insert additional feed rates so that the machine can work ˝normal˝.
Greetings from Slovenia.
Ales.
Ales.
