jogging a haas
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: jogging a haas
    Mar 2008
    vacaville ca
    513
    74
    140
    Default jogging a haas
    Running a Haas (TMP2 2017 model)for the first time, and when selecting the .1 mode and turning the wheel the axis continues to travel after the wheel has stopped, I'm sure its buffering the pulses. Is there a parameter that will stop the axis travel when the wheel stops?
    Feb 2019
    New York
    287
    256
    No, .01 will jog at the same speed at full tilt and have less overrun when you stop. Don't use .1 it is famous for jogging the head into objects unintentionally. It is possible to disable .1 in the settings, I suggest you do so.
    Jun 2006
    Thunder Bay Canada
    1,853
    589
    324
    We had an SNK bed mill Fanuc control. Came from the manufacturer with X1 and X10 settings for handle feed. I got the techs to install the X100 setting.
    Bad idea!
    Cranking this thing to get it moving faster could be disastrous as the table would keep moving until all of those multiplied pulses were satisfied.
    Same sort of problem the OP has just on an older machine.
    Jan 2014
    Washington
    5,333
    964
    2952
    Quote Originally Posted by 706jim View Post
    Bad idea!
    Some models of Fanuc have a parameter to disable buffering pulses from the MPG. For example setting 0 to parameter 1413 on a 15 series (~30 year old control) disables MPG buffering. Maybe the tech that set up the X100 for you did not know all he should have.....
    May 2011
    New Jersey
    2,606
    241
    1409
    Quote Originally Posted by AJ H View Post
    Seen it done...especially on the z axis...my first day as an operator came with the .1 warning, I never forgot it lol. Seen a few tools disintegrate
    It's bad enough when you are gapping the tool pickup and you bring it down in .01 and fat finger or forget to hit .001 or .0001...I normally reverse the jog wheel before I go to touch off, didn't do it the other day and wouldn't ya know it...it was still in .01. fortunately it was a center drill so it just left a little mark that I later plugged and hand finished to match because I couldn't stand that I did it lol.
    Nov 2002
    3,345
    2016
    855
    This ↑↑↑↑
    I have to train my guys to NEVER use the 0.1 feed, UNLESS you are nowhere near the part.
    Did I find a junior operator had T1 about 20° off X axis while in the toolholder, due to running the tool into the stock? Yes I did!
    (run on sentence)
    Did the part get scrapped due to mis-tagging G54 with now crashed tool? Yes it did.
    Now, NO MORE using 0.1" REGARDLESS.
    If I catch someone using 0.1"
    First offense = written up
    The 2nd time, the same written up, but they get to take 3 days of NON-PTO.
    The 3rd time....
    Oh heck, nobody will do that.
    Well, except for as91000 or whatever. HA!
  7. Likes snowshooze liked this post
    Apr 2013
    261
    118
    Wow,
    This sounds horrible. I had that on my hobby mill using mach 3. Great way to snap off Haimer probes. I never would have thought it could happen on an industrial grade control though. I jog like a mad man on the Brother, but never had such behavior.
  9. #8
    Jun 2015
    Minnesota
    601
    12
    211
    Ah... people... they're called Jog and Rapid Modes. They come with little X-Y and Z buttons. No over running or anything. Save "Handle" for when you're close.
    I see folks in videos spinning the hell out of they're hand-wheels. Makes me crazy. Even the part timer I have come in once in awhile started on that. Put the ixnay on it immediately. Learn to use the jog buttons.
    Honestly I find the problem in this thread surprising. Wouldn't have even imagined it if I hadn't read it in a book somewhere.
    Edit: On closer inspection I see that as always, a misplaced decimal point will mean something unwanted. Never having even touched a Haas, I breezed over the 0.1 per click problem being talked about and was thinking 0.01. Yes, 0.1 should not even be an option. Even a bumped handle could spell disaster. All the same, I'm still sticking with my jog buttons and dial spinners drive me crazy bit. :-)
  10. #9
    Feb 2014
    FL
    3,738
    12347
    4400
    Quote Originally Posted by 13engines View Post
    And for those machines with no jog buttons? I'll stick with my handles. Which thankfully don't buffer pulses. Stop spinning, stop moving. Period.
  11. #10
    Feb 2003
    Alabama
    530
    29
    285
    My 2009 VF2 has a parameter or setting (don’t remember the number) that disables the .1 handle button. I’ve got it turned on.
  12. Likes plastikdreams liked this post
  13. #11
    Jun 2015
    Minnesota
    601
    12
    211
    Quote Originally Posted by TeachMePlease View Post
    And for those machines with no jog buttons? ...
    Wow... I had no idea there was such a thing as no X-Y-Z-4 buttons. For those without, please, spin away!
  14. #12
    Sep 2010
    Anchorage, Alaska, USA
    716
    307
    142
    Quote Originally Posted by doug925 View Post
    This ↑↑↑↑
    (run on sentence)
    The 3rd time....
    Same here.
    Broke probe stylus and other stupid things a couple times.
    .1 to get within a couple inches only.
  15. #13
    Jun 2006
    Thunder Bay Canada
    1,853
    589
    324
    Another consideration was the need to translate English to Japanese. We asked them to so this, they did it and we learned to be REALLY careful on the 100x setting.
  16. #14
    May 2011
    New Jersey
    2,606
    241
    1409
    Quote Originally Posted by Eric U View Post
    Same here, when your normal work area is the size of a kurt 6" is there really a need?
  17. #15
    Feb 2014
    FL
    3,738
    12347
    4400
    No joggy joggy, only spinny spinny.
  18. #16
    Nov 2014
    Florida
    5,501
    2190
    2716
    Every one already said, but yea, turn the setting ON to disable .1 jog and done. No reason (IMO) to need to jog at .1
    While we are at it, you can use jog hold(?) at .01 and use feed overide to make it go faster, or you could, not sure if that is changed on NGC.
  19. #17
    May 2011
    New Jersey
    2,606
    241
    1409
    I think it's jog lock on haas
  20. #18
    May 2019
    Michigan
    2,242
    1037
    1496
    Setting 163. Turn it ON to disable 0.1 mode.
    I also strongly urge you to do so.......
  21. Likes BT Fabrication, mountie, kinetiq liked this post
  22. #19
    Mar 2008
    vacaville ca
    513
    74
    140
    not what I wanted to hear but thanks for the heads up on it. Like van said about buffer disable, I knew fanuc/siemens had that option thought haas would to. but now I know what I'm dealing with and thanks for everyones input on that.
  23. #20
    Jul 2016
    Indiana
    328
    39
    Try param 209:25
