Kenna DFT drills & Stainless 316
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Jan 2020
    NORWAY
    52
    31
    5
    Default Kenna DFT drills & Stainless 316
    Hi,
    Been drilling with our Kenna DFT Ø47mm (approx. 2 inches diameter) drill into 316 stock today. We just weren't able to break chips, just hefty strings. We're drilling deep - 190 mm. Started off by using recommended values, but tried changing speed/feed as we went along. The problem isn't that it's not cutting, but when it doesn't break chips it packs the flute and causes trouble. Any of you guys used these DFT drills in 316? All tips are appreciated! Trying new and different inserts tomorrow. Machine is a Haas ST30Y which was seeing about 70% spindle loading. RPM was around 1000 and feed approx 0,12mm/rev.img_20200528_172853.jpg
    Edit: We realize that we're going deeper than recommended here, so pecking is last resort if we can't make chips.
    May 2019
    Michigan
    1,481
    426
    678
    Your feed is too light. You are at .0046 ipr (translated for us primitives ).
    That size insert drill should be able to handle closer to .01 ipr (0.25 mm).
    Just gradually increase the feed rate until you hear it start to grumble, then back it off a touch.
    A Haas machine can run at well over 100% spindle load, FYI.
    If that still doesn't work you probably have the wrong chipbreaker.
  3. Likes Schjell liked this post
    Jan 2020
    NORWAY
    52
    31
    5
    Thanks, will give that a try tomorrow! Getting a MS? Insert tomorrow that's supposed to help breaking the chips.
    Mar 2015
    Michigan
    424
    95
    146
    Kennametal recommends .004 - .008 IPR on those drills in stainless, so you're in the ballpark. I agree with CS though, a little more feed might do well.
    I've never personally worked with 316 though. Isn't it known for being wildly inconsistent?
    Jan 2020
    NORWAY
    52
    31
    5
    Not much experience myself with 316 other than asking a lot of companies to make parts out of it for us earlier🙄.
    So far my personal experience is that it breaks chips well when doing outside turning and it's ok during boring. Drilling is a bit tricky so far though, but that big drill is a monster so it will be a bit nerve-racking to bring up the feed some more and try. Sounds like a traincrash when it's ploughing through the 316.
    May 2019
    Michigan
    1,481
    426
    678
    Quote Originally Posted by Schjell View Post
    Not much experience myself with 316 other than asking a lot of companies to make parts out of it for us earlier��.
    Your chips are a classic example of feeding a little on the light side. They are "accordion" shaped now, but as soon as you give it enough feed they will come off in 6s & 9s.
  8. Likes Schjell liked this post
  9. #7
    Feb 2007
    Aberdeen, UK
    3,912
    1389
    1588
    Quote Originally Posted by ChipSplitter View Post
    That would be a very heavy feed rate for that drill. Good chance of crunching the centre insert.
  10. #8
    May 2019
    Michigan
    1,481
    426
    678
    Quote Originally Posted by gregormarwick View Post
    It's a 47 mm drill.
    I've pushed a 32 mm OSG drill to .008 ipr.
    True, it could be a bit high, but the point is he has room to go up with the feedrate.
  11. #9
    Feb 2007
    Aberdeen, UK
    3,912
    1389
    1588
    It's a 47 mm drill.
    The chipload capability scales with the size and geometry of the insert, not the size of the drill. The centre insert has effectively zero surface speed, and it's ability to withstand massive pressure determines the maximum feedrate attainable. I have some 50mm insert drills that will handle .25mmpr, and I have some 100mm drills that will absolutely not.
    DFT drills use W shape inserts, which are pretty fragile at the corners. I am prepared to be proven wrong, but I think that .25mmpr is really pushing it for that drill.
  12. Likes Lastuneste liked this post
  13. #10
    Jul 2006
    Hillsboro, New Hampshire
    9,278
    2199
    6436
    It's a 47 mm drill.
    At some point you have to worry about the "springiness" of the machine. If you get to a load where you start backing the drill up until there's enough force to bounce it forward then you'll have spiking loads on the inserts that could destroy them.
    The other aspect is as above but now add work hardening to the material surface...
  14. #11
    Nov 2013
    Utah
    4,891
    1294
    2765
    Okay, get your grains of salt ready.
    I use almost exclusively DFT style Drills. I've crashed them, melted them, broken them and made $1000's with them. It's not a coincidence that I use them as much as I do. I really like them....I use KC7225 for both peripheral and center pockets, and they are the only inserts I use. I usually run alloy steels, 300 and 400 series SS.
    In my experience, the advantage of these Drills is that they are very tough, heavy bodied Drills. As far as MRR goes, I found that they run more productively with higher SFM and lower Feeds. At 1000 RPM you're only at 50 SFM. I would double that and leave the Feed alone (to start). There is a very unique sound that it'll make when it's running best. It'll make the office people poke their heads in to ask if you need an ambulance. It's literally the highest pitched shreek ever.
    R
    Disclaimer; I understand that at a glance my suggestion is against conventional wisdom for SS. Don't go over 200 SFM and don't stop feeding.
  15. #12
    May 2019
    Michigan
    1,481
    426
    678
    A Sandvik Corodrill 880 is really bad too. I don't know why it's so high pitched but it makes my ears bleed LOL.
    OSG and Ingersoll never have noise issues in my experience, they just make a low grumbling, growling noise.
    YMMV
  16. #13
    Mar 2015
    Michigan
    424
    95
    146
    R
    I think he's running closer to 500 SFM...
  17. #14
    Jan 2003
    Canada
    11,404
    5777
    3522
    Lots of coolant pressure helps. Sounds like you're probably running on the standard pump?
    I find the 145psi of my machine to be about minimum, more would be way gooder.
  18. #15
    Jun 2012
    Michigan
    5,202
    4778
    3149
    YMMV
    I agree, as much as I like Sandvik, some of their 880's will make you go deaf.
    On that note has anyone used the Kyocera Magic Drills?
    Night and Day difference. They are so quiet and cut like butter. And the inserts are tough as nails.
    And I believe the bodies are a lot less in price than Sandvik, Iscar, Kennametal, etc...
  19. #16
    May 2019
    Michigan
    1,481
    426
    678
    Quote Originally Posted by Mtndew View Post
    I like the performance of the Corodrill 880s but the inserts are wickedly expensive, too.
    I haven't used Kyoceras but that is good to know. Who do you get Kyocera stuff from?
    PF Markey? Shively Bro. ? Iwen?
    I personally like Ingersoll, OSG, and even Korloy for insert drills. Not a fan of the Iscar DR-Twist, though.
  20. #17
    Jun 2012
    Michigan
    5,202
    4778
    3149
    We get them from Carbide Depot. They have really good pricing.
    The site lacks a lot of images, but they do have links to Kyocera's official catalog so you can get the part numbers.
    KYOCERA DRZ MAGIC DRILL
  21. Likes ChipSplitter liked this post
  22. #18
    Jan 2020
    NORWAY
    52
    31
    5
    Ok, found the sweet spot today in terms of chipbreaking. See attached pics of ideal setup for what we were doing. Tried Robs setup as well with the inserts he uses, but that didn't work for us. img_20200529_142954.jpgimg_20200529_142909.jpgimg_20200529_103306.jpgimg_20200529_102352.jpg
    See my latest post. Wrong feed & speed shown on screen shot.
  23. #19
    May 2019
    Michigan
    1,481
    426
    678
    Nice!
    So did you use different inserts or the same ones? I converted your feedrate and came up with .0086 ipr (.2236 mm). Is that what you are running?
  24. #20
    Jan 2020
    NORWAY
    52
    31
    5
    Used the inserts shown on picture. We have the local Kenna sales rep working along with us, so it's all his credit that it worked out so well.
