Kitagawa S1875 Cylinder Rebuild
jjohns
Oct 19, 2018
I'm in the middle of trying to replace the O-rings in my Kitagawa S1875 cylinder. I can't figure out how to gain access to the bolts holding the cylinder together. I believe the bolts are between the aluminum casting and the rotating portion. I assume I'm on the right track, but I'm hoping someone can shed a little light on the subject, before I do some damage.
Thanks.
Having the same issue with my Samchully HYHL 2511. I do wonder if just replacing the o rings is enough. Often the chrome flakes and replacing the o rings is only a temporary fix. I guess you dont know till you tear it down.....
I have had to grind the piston shafts down and have them hard chromed then re-ground if the diameters are pitted. Otherwise the o-rings will not last very long.
