dandrummerman21
Stainless
- Feb 5, 2008
- MI, USA
We just got a '98 Kitamura H400 with 15m control. We are still getting it set up (took sheet metal off, new air and lube lines, etc). Still doing some minor work on it but I am almost ready to put it to work.
Anyway, we have a '93 Mycenter 3 already that has a problem for us: when you have a M0 in the program (or M1 with optional stop on) the spindle shuts off and doesn't turn back on afterward. we never did find a diagnostic parameter to change on the mycenter 3.
Anyway, I just tried it on the new H400, and it does the same thing. The spindle turns off when the machine stops, and it doesn't turn back on.
I can work around that if necessary, but I hate it. None of the other machines behave like that (Leadwell, Makino, robodrill), only the kitamura does.
So the question is, does this thing have a parameter or keep relay that changes this? I have the ladder and manual, I did browse through it and did not see anything of the sort. I really hope it has a setting I can change for that. Seems like a popular machine for the era, there's a bunch of them out there, so somebody ought to know if I can fix this?
