greenbuggy
Stainless
- Oct 6, 2005
- Firestone, CO
Recently bought a KO Lee S618L1 with a Leematic 1000 control from an auction here in Colorado. It did come with a set of books, auction description said it "only works in manual mode" and from what I've gathered from reading the manual that was included if it's been powered down for long enough you have to re-enter parameters by going into setup off the main menu, which shouldn't be a big deal. Until setup is completed it won't let you program it, run programs or even jog the axis...literally can't do anything except run it in manual. I do fortunately have a full set of parameters someone sketched out on a sheet in the manual.
Unfortunately for me, the factory password/passcode specified in the Leematic 1000 control manual (5280) doesn't get me into the setup menu, it just bounces me back to the main menu like I entered the wrong password. Any ideas on how one might reset it, or other combos to try for this machine? Have tried last 4 of control serial, thousands, control revision and a few others but don't have the time to enter 10k combos manually to see which one unlocks the thing.
