vmipacman
Cast Iron
- Nov 21, 2014
- Virginia, USA
I have a best practice question. Leveling a small bridge mill, travels are X-90" Y-56". Using a Starett 12" precision level. There are 24 leveling screws.
If I level off the table in all areas of travel and checking all corners of the table, then put the level longways on the ways directly I get a different number. The table is level but the ways are ~.003 out of level over 12”. That’s about 6 ticks on the level. The level is .0005 per graduation. Should I be concerned about a difference between table and directly on ways or does un-even wear on the turcite (and generally an imperfect world) account for the table being level but not the ways themselves? It’s a bit like getting a wet noodle to fit a straight line but I don’t have a feel for "good enough". Leveling just the table, I have level reading ranging from dead on to .0015 per 12”(3 ticks) depending on where in the travel I am and where on the table.
Also, since functionally all the action happens directly under the spindle, should I really only focus on the checking level of the table UNDER the spindle rather than the extremities of the table?
Just let me know if i can stop overthinking this now
