Looking for suggestions on what I should do with this operation on the lathe. I'm trying to do a finishing pass using a DCMT Sandvik (2015 grade) insert. Running 960 sfm (880-960 recommended) but I only have 3k rpm on the lathe so it hits that max somewhere on the face of the part. 0.004"/rev and leaving 0.004" stock to take off afterwards.
The speed is on the high end of recommendation, and feed is on the lowest end. Depth is suggested a lot more, but I've found this operation worse at their recommended 0.02" minimum to leave.
My parts as you can see are a pretty tapered surface and I'm just running this on the large taper and face of the part (top). If I finish the OD it comes out beautiful with this DCMT or even a CNMG insert. So it's the taper geometry that seems to be killing me. OD of the part is just under 3.25"
In the past I have used a Kennametal VBMT, but insert grade wasn't ideal for stainless...repeating the finishing pass worked a bit. I also have tried a Sandvik VNMG cermet insert which I had read was supposed to be good...finish only average. The DCMT has seemed about the best, just consistency and edge life is what I'm hoping to improve.
Any suggestions on a specific insert, or what nose radius I want, or feed/speed...I'm open to it all!
Pics go from worst to best finish. The last one still has a bit of waviness in person, but not easy to pick up on cam. The insert wears just a bit and can lose that finish after just 2-3 parts.
